Hi iv got a Goldman's freest sd I can't get any channels it just says no signal what can I do presentable keith
  • Televison & ... Master
  • 1,527 Answers
Hi turn the power off unplug it, see if there little reset button on the back of the box, check aerial lead, reconnect retune, thanks
shaun
Posted on May 20, 2017
2 out of 5 signal reading on cobra cb radio
You'll need to find another CB radio for someone to check to see if they are receiving your transmission.
Aug 16, 2012 | Cobra 19 DX IV CB Radio
My VIP722 DVr keeps showing that I have a complete loss of signal. This goes for awhile and can receive no HD channels. By going to DVR I can then go to guide and get SD channels only. But then after...
Hello this is Nick Franta with DISH Network.
What error message are you receiving on your screen? There should be a 3 digit number in the top right of the message. Has there been any bad weather in the area which may have affected the signal?
If you haven't been advised to already, I would suggest doing a hard reset of the receiver by unplugging it from the outlet for 10 seconds. When you plug it back in the receiver will reboot itself for you. If you are still getting errors hit the menu button then 6-system setup, 1-installation, 1-point dish, and then hit check switch and then test. All your satellites should show green. If not we would need to send a tech out to address the issue.
Hope this helps!
Jan 12, 2011 | DISH Network 311 DTV Receiver
My Hd channels are saying complete signal loss then later they are available again, then complete loss again. Can switch to non hd channels but want the Hd. What do you suggest
Hi edhayes27 my name is Mike Houston of DISH Network Executive Office. This posting in FixYa shows you have the 311 receiver; this receiver will only show SD channels. We do have the VIP 211 which will show in HD and SD channels. If possible can you verify the model number of your receiver, which indicates you
Hi,I would like to remove my car stereo to enable me to install a Xmas present. The car is a Hyundai Sonata 2005 Model. Thank You Keith
Hi Keith,
"Ric" at Classifieds1000 explains the process better then I can:
http://autoforum.classifieds1000.com/Hyundai-Sonata/2005_Hyundai_Sonata_radio_removal
I would however wrap a flat head screwdriver or stiff/strong butter knife in electrical tape to pry the trim to avoid scratches.
Best of luck!
May 02, 2010 | Car Audio & Video
"No Signal" on channel 9
Appears you are getting a weak signal at the channel 9 frequency. If you are using a signal splitter, try replacing it with an amplified unit since splitters always do the deed but they can and will reduce signal strength significantly.
Also remember that digital signals are not like the older analog ones that they replace. They are not subject to ghosting but are weaker and susceptible to all sorts of interference such as a leaf, rain, etc. Your antenna is good.
You also might try raising the antenna. The higher it is the better it works. (use some wire to further support additional height) Why do you think transmitters are so tall?!?!?
Mar 22, 2017 | Vizio VW32L 32 in. LCD HDTV
Cobra 19 DX IV CB Radio Gets no signal at all
my only idea is the frequency that Canadians transmit/recieve on is different than us down south (in the USA). I know Europe and the UK use a different frequency range so my guess is that Canada uses a different radio frequency range than the U.S. making you unable to communicate with fellow radio users. You may be able to search the frequency range for Canada vs. the U.S. and see if there's a difference. Hope this helps...and again, it's just a thought.
Montana, USA
Jul 08, 2008 | Cobra 19 DX IV CB Radio
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Recording
you have to play the vhs before hitting the record button or the lyra will pick up no signal i had the same problem recording my dvds
Aug 18, 2006 | RCA Lyra RD2780 Digital Media Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
