Question about Sewing Machines
Are the looper covers available? My cover is broken
  • Sewing Machines Master
  • 11,769 Answers
Search for:
Make Model replacement parts
or contact the dealer.
Posted on May 20, 2017
The looper safety cover wont close thus machine wont sew
if there is a spring in it, you may have to have the spring check or replaced
May 07, 2016 | Sewing Machines
How do I thread the cover stitch looper on the Elna 744?
On my coverstitch,the lower looper swings out to the right so I can access the thread eyelet, wondering if yours is the same?. And i dont pull the thread up to he top, just leave a tail loose, make sure i swing the looper ack to the left, then close cover and stitch.
Mar 01, 2015 | Elna Sewing Machines
I have juki 7923. It is cover stich. ones in wile the looper is not caching what shoud i doo
Hi
i try to attach PDF file for how to adjust top cover thread spreader and how to adjust looper timing but the upload only support gif-jpg-png file,please email me to send PDF file to you.
BEST REGARDS
Jun 12, 2014 | Juki MO-644D Mechanical Sewing Machine
Janome Overlocker has power to the light but when I press the pedal nothing happens. Any suggestions to resolve this issue?
can you hear the engine humming when you plug it in? if so, that eliminates electrical supply to the engine.
If you manually turn the flywheel towards you does the loopers and needles move through a stitch sequence? If yes, then its not the main drive gears inside. If there is no movement or if a looper just "flops" around, you've got an internal drive problem, probably time to take it to a technician.
Lastly, check that the looper cover and side cover are fully closed as they will have safetly cutouts on the doors that prevent the machine from operating when the door is still not fully closed.
Nov 02, 2011 | Janome MyLock 634D Mechanical Sewing...
When I thread and use Three thread cover Stitch the right hand needle thread continously breaks while sewing I've changed the tension and no joy I was sewing hem on leasure wear
Try rethreading all the threads making sure you thread in the recommended order: Upper Looper first, Lower Looper second with the tail Crossing Over the Upper Looper as the last step, then thread the needles.
Mar 23, 2011 | Bernina 2500DCET
Bernina 800d sewing machine
You might take a look on ebay item with bernina 700d/800dl instruction manual
Apr 28, 2010 | Bernina 1008
I can't find my Bernina Serger 800 dl manual - how do I thread for a 2 thread rolled hem, and do I need a upper looper cover and that the heck is that anyway?? Thanks
From what I have read this manual is less than desirable. Neither is the one for the brand that I have.
You may have better guidance if you purchase and use Nancy Zieman's "Serge with Confidence". I have found it very helpful.
For the two thread rolled hem, the looper cover is used to "trick" the looper into "thinking" it is threaded.
On my serger (not a Bernina), this is referred to as a "subsidiary looper". It is a spring type mechanism that fits in a small hole at the top of the upper looper.
You use a rolled edge presser foot; right or left needle; stitch length @ normal or wider; stitch length @ 1mm for the left needle/0.5 for the right needle; differential feed @ normal; needle tension - tighten; lower looper tension - normal or looser; two thread looper cover - engaged.
Test and adjust the tension as needed before making the rolled hem on your garment.
I hope this helps.
Apr 18, 2010 | Bernina 1008
My machine will not stitch....have tried every combination and it keeps dropping stitches
Start with brand new needles. Make sure you use sharp needles for woven and ball point for knits.
Remove all threads from machine. Open all covers,, including top cover (under thread tension). Remove all lint. Oil moving parts. Replace covers.
Thread your machine from right to left. In other words, start with the lower looper, upper looper, right needle, then left needle. That should solve your problem. Thread must be threaded in specific order and through every loop in order to work. One miss threaded loop will cause the machine not to sew properly.
Apr 16, 2010 | White Sewing Superlock 2000 ATS Mechanical...
Easy Lock Serger Broken Lower Looper
You will need to buy a new looper from a dealer with a spare parts account for this brand.
It is tricky to set up the loopers without a service manual, so best suggest you also have them install and service the machine at the same time or you risk breaking the new one if it is even slightly out of alignment.
You may also find that parts availability at this time of year will be restricted as many businesses and suppliers close for several weeks.
Dec 26, 2008 | Sewing Machines
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
