Question about The Office Equipment & Supplies
Bizhub 215 shows fuser error at the time of switching on machine after long rest.after clearing error it works fine. i need how to increase the fuser temperature.
  • 13 Answers
SOURCE: How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Posted on Nov 30, 2007
  • 214 Answers
SOURCE: Konica Minolta bizhub 350 Error c0500
did you do a trouble reset ?
Posted on May 11, 2008
bolinlamar
  • 157 Answers
SOURCE: Need to clear the error code
Put the MFC into Maintenance Mode
Press the Menu and Start Keys at the same time then press the up arrow key 4 times the machine should display "Maintenance " in the LCD display
Press the 8 key twice, Display should show Part Replacement
Press up or down keys to select "Reset Fuser" press OK or Start Key to reset the counter of the fuser
To Exit Maintenance Mode press the 9 Key twice
I hope this helps.
Posted on Aug 20, 2009
SOURCE: C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
  • 406 Answers
SOURCE: fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Posted on Nov 16, 2009
Konica-Minolta bizhub 215 giving c3451 error message?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
Bizhub c 450 error c 3752
Fuser Heat Error. Sometimes this code can be cleared by using the reset procedure outlined below. If the code returns then you will need to have the unit serviced.
Reset Procedure: 1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Apr 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
How do i clear message c2558 for the konica minolta bizhub 215
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Feb 24, 2014 | Office Equipment & Supplies
How to reset error c3451 in konika minolta 215
clear/stop held down and turn the machine on, IF THIS CODE COMES BACK DO NOT RESET AGAIN IT IS POINTING TO FUSER UNIT IT CAN CATCH ON FIRE GET TECH OUT AND REPLACE THE FUSER
Feb 14, 2014 | Konica Minolta bizhub 200 Printer
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
Konica Minolta showing error code c3451, cannot clear it. Please help
Hi this is an issue with the fuser unit not getting to the correct heat level check there is no bits of paper stuck in the fuser unit check that the heater lamps are coming on h1 and h2
also check the thermistors you can replace the fuser unit assembly if it still does not work after replacing the fuser unit you will need to change PU1 and last resort PWB-A
the above will resolve your issue if you hold down the utility meter key and then switch on the machine keep the utility key held down for at least 30 seconds after switching on the machine after 30 seconds take your hand of the the utility counterr key and on the display it should come up with trouble reset press the screen on trouble rest the machine will reset you could try this first to see if machine resets
let me know how it goes
Feb 07, 2011 | Konica Minolta Bizhub 222 Black and White...
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
37 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
