Question about Champion Garden
Need to change pull cord on my champion lawnmower
  • 45 Answers
SOURCE: Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Posted on Sep 27, 2008
  • 84 Answers
SOURCE: lawnmower
what do you mean doesn't engage? doesn't start, doesn't let you pull, doesn't cycle, what?
Posted on Jun 24, 2009
  • 294 Answers
SOURCE: the lawnmower won t start after pulling the start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Posted on Oct 08, 2010
  • 6468 Answers
SOURCE: Lawnmower hit a stump and now can't pull starter cord
you may have bent the crank shaft if it pulls hard and pulls back then remove the flywheel and check the key
Posted on Apr 02, 2012
  • 10 Answers
SOURCE: champion 35 lawnmower hunts
Clean the air filter (foam type) in warm soap water then apply some oil soaked in, it will smoke afterwards for a short time. Or possible minor adjustment too the mixture screw on the side of the carburetor spring loaded. Allan
Posted on May 09, 2012
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
How to change the pull reel
Just click on the link below and it will have videos that will show you how to change the pull reel. Good Luck and I hope this helps you out. : > )
How to replace a lawnmower pull cord - YouTube
Jul 24, 2014 | Toro Super Recycler 21" 159cc Personal...
Replace pull cord
Go o you tube on line, how to replace pull cord mower
May 24, 2014 | Champion International Champion& Small...
Starter cord on lawnmower will not pull out
Hi Mary. You will need to remove the starter box on your mower. The coil box may be rusty or the pully may need fixing. Try using some oil spray and see if the pully now works. If the starter coil is clean the mower may be ceased.
Jul 27, 2013 | Garden
Champion 35 lawnmower hunts
May 09, 2012 | Garden
There is no slack in my pull cord so i can't get it started.
Change the pull cord do you really need someone to tell you this!!!! In any case try this website and try using some common sense next time PAL. Go to they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Jun 07, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Oil in my Champion lawnmower is emulsified. How can I drain the oil tank?
You can add a solvent like Diesel Fuel to it (engine) and pull the starter cord or starter to move it will begin to break up the mess possibly.. You can also add Gunk Car Engine Cleaner too, to the engine oil, not the fuel.....A regular mower only holds about 20-21 oz of oil so be forewarned...
This is an interesting it even worth demulsifying?
Jun 04, 2010 | Garden
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
Top Champion Garden Experts
Lawrence Oravetz
Vernon Taylor
john h
Are you a Champion Garden Expert? Answer questions, earn points and help others
