Question about Garden
My x300 stops running some times when mowing forward I can ingage and disingage the pto with the key on and it usually restarts do I have a bad switch or is there a wiring problem?
  • 109 Answers
SOURCE: cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Posted on Jun 03, 2009
  • 33 Answers
SOURCE: Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Posted on Mar 26, 2010
heatman101
  • 43501 Answers
SOURCE: PTO problem on a model
I would be looking at the ignition switch....but before replacing it I would be looking for a friend with an electrical meter and checking the wiring for power coming out of the switch to the cluthch, this way you can narrow it down positively before buying parts.
heatman101
Posted on Jun 18, 2011
  • 773 Answers
SOURCE: I have a cub cadet
Sounds like either a wire is detached from something or simply the switch is bad. Also depending on the model there is some times a fuse for the electronic clutch.
  • Make sure all wires are connected to the switch, and to the clutch.
  • Look under the hood and look for any fuses that will be attached to a wiring harness and make sure they are not blown.
  • Make an inspection of the belts. Make sure the belt is riding on all of the pulleys.
If you are still having a problem, it may be the switch. With the mower key on, and the engine not started, (DO NOT START ENGINE, ONLY HAVE KEY POWERED ON!) have some one engage the PTO switch while you listen for a click from the deck belt drive pulley. If you do not hear a click form the pulley, which has the clutch attached too, then it is not engaging. This is possibly the switch.
Remove the switch. there will be 2 wires on it. Doing the same as before listen to the deck belt drive pulley(WITH THE ENGINE NOT RUNNING, BUT KEY ON.) whiles some one touches the 2 connectors on the wires from the switch together. You should hear a click. If you do then you have a bad switch. Easy fix. You can even Start the tractor, with every one clear of the mower, and then touch the 2 wires together and the blade should come on.
If you still do not get the blades to engage then most likely the clutch for the blade engage is shot. this is a more expensive replacement. There could also be a loose or broken wire some where you haven't found. If every thing is intact, then I would look into a new clutch for the PTO.
Posted on Aug 10, 2011
  • 640 Answers
SOURCE: MY CRAFTSMAN DYT4000 RUNS GOOD WHEN THE PTO IS
It sounds like your mower is equipped with a reverse safety switch. This switch will prevent you from mowing in reverse by killing the engine, like any safety switch. You just need to investigate it and decide if you will disengage the blades to back up or if you will disable the safety switch. You mentioned that there were wires cut. Do you know what they were? How many were cut? I suggest that you trace them out to see what they are, where they go. The previous owner may not have wanted to deal with the safeties for a number of reasons.
In regards to the reverse safety switch, many mowers do not have them. As in they do not come on all mowers, historically. I do not know if they are designed into all the newer ones or not. I work on older mowers and whether or not they are on a mower seams to depend on the manufacturer (on older mowers). My seven or eight year old Craftsman does not have one, while a twelve year old MTD may.
I hope this is helpful for you.
Posted on Aug 22, 2011
Testimonial: "thanks will try to check for a switch,,and abought all the wires were cut by a dog i got a wireing ***, and reconected and reran all new wires "
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
PTO stopped working. What can cause this to happen?
bad safty switch or bad switch or pto burned out pto cost 200.00 switch engagement 15.00 or bad safty switch 15.00 pto dont go out that often not unless your mowing heavy grass
Aug 29, 2014 | Garden
Why won't the switch on my 2084 cub cadet stay ingaged
Your battery may be low. Check water level and charger often is power is low the electro magnet will let go. Holding switch could cause too much power and burn out coils on magnet.
Jul 18, 2014 | Cub Cadet Garden
Can malfunction of PTO or other safety switches prevent start up of mower
You didn't state the model or brand of tractor, but usually the way the cranking circuit work is, from the "S" terminal of the ignition switch, the circuit runs to the PTO switch, if it's in the OFF position, the circuit then runs to the pedal switch, if it's in the DOWN (or brake on) position it then runs to the solenoid. On other tractors, from the ignition switch, the circuit runs to the pedal switch first. (The seat switch isn't used in the cranking circuit).
Any switch can go bad, but I would more likely suspect the pedal switch or loose connection at either switch. (But it could actually be the PTO switch).
Try tracing the circuit from the "S" terminal of the ignition switch through the PTO or pedal switches to the starter solenoid. You may get lucky and find something obvious.
If you find nothing, try jumping across the pedal or the PTO switch (only two terminals are used in the cranking circuit, trace back to ignition switch for the incoming, outgoing is usually directly adjacent). Jumpering will take these out of the circuit and tell you if either is bad internally.
Lastly, there's always the possibility that the ignition switch is bad. (Doesn't happen all that often, but it's suspect as well). Jumper from "B" terminal to "S" terminal will take it out of the circuit.
Aug 21, 2012 | Garden
Pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
May 23, 2012 | Garden
MY CRAFTSMAN DYT4000 RUNS GOOD WHEN THE PTO IS INGAGED WHEN GOING FOWARD WORKS LIKE A CHAMP, BUT WHEN PUT IN REVERCE THE ENGINE WILL DIE, UNLESS I DISINGAGE THE PTO PLEASE HELP ,, GOT THE MOWER USED...
Aug 22, 2011 | Husqvarna Mcculloch Riding Lawn Mower 185...
My lawn tractor just quit running, battery fully charged, won't do anything when switch is turned on. Can the ignition switch be bad?
When you say it quit running, did it stop while you were mowing? Or did it just not start one day. Could be the ignition switch, but not likely. There are several safety switches on your mower. First is the operator present (switch in the seat) then there is the switch on the clutch that requires you to hold the clutch in when you start. Then there is a switch on the PTO for the deck that must be off to start. Without an exact model number, I can't look at the exact wiring schematic, but this is generally how they work. If you have a tester, and know how to use it start at the battery, look for 12 V. Then test from ground to one side of ignition swithch. Then to the other while the key is in start. Then find wires to seat switch. This switch should keep the mower from starting and keeps the pto engaged usually. then find the switch for the clutch/brake. test both sides of that. Finally test the small terminal on the starter solonoid. If you're getting 12V to the solonoid, and you have a good ground on your battery and it still won't start, could be the solonoid. If it actually quit while you were mowing, I'd check the seat switch and pto switch.
Jul 12, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mar 17, 2010 | Garden
My pto will not ingage
most of the time its linkage adjustment or cable.Its been my experiance that if you let out lightly on the clutch moveing a little bit forward or reverse while ingageing the PTO that they go in smoother and completely
Sep 06, 2009 | 2000 Ferrari Enzo
Blades will not ingage
your electric pto clutch switch is bad replace it
Nov 14, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
