Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 1/2 hp 139.53648
Changed large gear without disturbing any other settings. now the motor only runs about 2 or 3 seconds and stops . nothing is jammed up as i dropped motor into my hands and tried it . still stops running after about 2 seconds , any suggestions?
  • blueslover12 Jul 26, 2009
    thanks but i never touched the worm gear. thats whats puzzling me. I'll take a look though. any other suggestions?
  • blueslover12 Jul 28, 2009
    thanks to all for the help . the rpm sensor was bad .
    Scholar:
  • 91 Answers
I agree with all the above. Your problem is with the rpm sensor 'little board'. Check to see that there isn't pieces of the shredded gear blocking the two black squares. Blow on them or whatever and make sure they are facing each other. Also make sure the sensor is plugged in. In almost all cases when replacing the gear you HAVE TO unplug the rpm sensor and sometimes if you haven't done it before the plug 'looks' like its plugged in. Unplug it and plug it in to verify.
The only other thing I have seen in older openers is that the spacers will wear out on the motor shaft and the black cap will go outside the rpm sensor area. With the cover off run the opener and watch the shaft where the black round cap is. If it moves more than one quarter an inch (or out of the rpm sensor area) then you need to replace the spacers that are worn out and gone. If you purchased a gear kit normally it comes with the spacers etc.
Posted on Jul 28, 2009
    President:
  • 3,197 Answers
Make sure you put the black cup bank on the end of the motor shaft and that it is pressed all the way on. Make sure the rpm sensor is plugged in. If neither of these is the issue then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Posted on Jul 25, 2009
  • Don Maggard Jul 27, 2009
    Only thing I can think of to check is the black interruptor cup on the end of the motor shaft and make sure the little board is plugged in good.
I have a Craftsman garage door opener (model 139.53637SRT - 1/2 HP) that stopped working. It sounds like the motor runs, but the chain and trolley do not move at all
The gears need to be replaced. You need
Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit available on amazon for around 20 bucks
Jan 16, 2011 | Sport & Outdoor - Others
We have the craftsman 1/2 hp garage door opener and it will only go up 1/4th of the way up and stops. I already reset the unit. One sensor is green and the other is yellow. Cleaned the yellow side sensor,...
The sensors only work when the door is closing. Remove the cover from the motor unit and check the drive gear. It is a white nylon gear and is probably stripped.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door motor dead
Keep checking for loose wires. Nothing about changing the gear should cause the motor to stop running. Check the wires on the start capacitor and follow the white wire from the motor and make sure it is connected.
Dec 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 HP Garage Door Opener stopped working. The motor is running but chain isn't moving. The actual door goes up and down fine.
Remove the cover and take a look. I'm sure you will find the drive gear is stripped. It is a white nylon gear just in front of the motor. You can buy one at any good door service company. The part number is 41A2817 and it comes with instructions.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN GARAGE DOOR OPENER PROBLEM
i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN 1/2 HP OPENER
Ok well the best advise I can give you is to open up your opener case should be a 1/4 nut driver or a Philips head screw driver. Make sure to unplug it first. Once the case is off, find a reqtangle black box with three white plastic screws they are what controls the limits. Chances are they got knocked off wheny ou were putting in the gear. check to make sure the wires are hooked up and find the placement of the limits make sure they can touch each other. Little tip I do for my customs is get a piece of sand paper and rub it agaist the metal contacts for the limits only. (after time lift master openers bind up a film and dont stop where they supposed to.) If your still not sure how the limits work plus in the opener and run it make sure not to put your hands inside the opener and nothing esle is in the way. Then adjest the limits as needed. That should take care of you if not go ahead and make another post ill check back with you.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't open or close
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
2. If the door runs fine your gears might br out of your opreator. Open the case and look for a white powder. If you see that and your gears look worn repace the gears with 41c4220a gear kit.
( with the 5 flashing the traveler is jammed up against the top bolt. The same part will fix the problem be sure to replace the bottom bushing on the motor bracket.)
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor runs but gear doesn't turn on my Craftsman 1/2 HP
What did you pay for near gears. curious. often get stripped gears in cold weather as door is frozen down to ground. if possible, kick door bottom edge with heel to break bound if you suspect it is frozen to ground.
Jan 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
186 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
