Question about Home
Why do garlic go green when in vinegar - Home
Garlic is it ok for the heart
I am not an expert on diet or herbal medicine but I frequently hear garlic is very good for the blood and circulatory system and I guess what is good for the blood can't be bad for the heart - whether you eat it raw, cooked or prefer to take a couple of garlic pearls daily.
Oct 17, 2016 | Home
Why does the water taste like garlic when the filter is still green
Hi Anonymous!
Hopefully you don't live in Flint Michigan!
Refrigerator filters use a timer to determine when the filter needs changing, sometimes the amount of water you use is higher than the 'average' amount and the filter may already be used up before it turns green.
Change the filter and if the garlic taste is still there, make sure if the Ice has the same taste - you may have some transfer of odor from the icemaker or fridge.
Thanks!
Feb 06, 2016 | Refrigerators
What to do with blood pressure 141/91. Can anxiety raise blood pressure?
anxiety can affect it. Try "CoQ10" 100mg 1 cap per day take when you eat. Also If you have w weight problem , Garlic, Vinegar and Honey will help. Lecithin caps are good for cleaning up the arteries.
Nov 13, 2014 | Health & Beauty
What is a garlic bulb?
A bulb of garlic s made up of several cloves of garlic. A bulb is similar to a daffidill bulb.
Jan 13, 2014 | Computers & Internet
How do you work the garlic press
Its easy . Open the two handles. Place the garlic basket screen into the well of the press. Before adding the garlic. Take a large butcher knife and cutting board. Place unschucked garlic cloves on the board . Lie the knife in a flat orientation on top of the cloves. Strike the side of the knife onto the garlic. Until the shell splits to easily remove the cover. Place the cloves into press and squeeze out garlic paste. Add one after another. Scrape the bottom of the screen press when a build up prevents pressing. Cleanup by removing the press bucket from the press. Wash the screen backwards while using a tooth brush or equivalent. Place in to Dishwasher utility basket for a thorough clean. If not . Air dry. Garlic is a joy. Have fun with it.
Nov 18, 2013 | Home
What to do to prevent crushed garlic to turn green?
Crush Vitamin C tablets and lightly sprinkle the powder over the garlic.
Sep 12, 2013 | Televison & Video
How to assemble brabantia garlic press
Garlic Press Stainless Steel Press ahead with our Profile garlic press .When time is pressing, you don't want to be stuck in the kitchen cleaning your garlic press. Our Profile garlic press has a removable perforated anvil, which makes it very easy to clean. You can even stick it in the dishwasher! Open remove basket or anvil.
Jul 25, 2013 | Home
Does pressed garlic get you as much garlic from a clove as chopping it?
No, there will always be less garlic when you press it. There is the most garlic from a clove when it is minced with a knife.
Feb 04, 2013 | Home
Is pressed garlic better than garlic powder?
I think fresh garlic is less strong than powdered so you just need to use more of it. Also depends on what youre making. And how lazy/time pressed you are. Most people swear by using cloves and not the powdered stuff but I don't think its so bad to use powdered garlic.
Feb 04, 2013 | Home
What is a garlic press?
A garlic press is a kitchen tool where you crush garlic quickly. You put the clove into the press and press down, pressing the clove through small holes to the other side. The garlic then comes out crushed.
Jan 10, 2013 | Home
Home Logo
20 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
