Question about Xerox Office Equipment & Supplies
I have XEROX 5735 photocopier with finisher. it showing an error, paper jam in area 5 area 5 in located in finisher.
  • 102 Answers
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Posted on Mar 20, 2007
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
  • 17 Answers
SOURCE: repeated paper jams
These errors are usually caused by a cracked DM Camshaft (Drum Maintenance). This was a very common problem for Xerox, they usually broke while under warranty, but there a heck of a lot out there that are just now going bad after a year.
You may or may not need to replace the "Motor Process Drive Gears" as well as the DM camshaft.
You might be able to talk Xerox into doing this as a warranty repair, if you ***** real loud.
Posted on Aug 21, 2009
  • 360 Answers
SOURCE: xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Posted on Jul 19, 2010
  • 160 Answers
SOURCE: Xerox Workcentre 4150. Paper keeps
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Posted on Aug 11, 2011
My Xerox docucolour gets a paper jam at the exit
Power off and unplug device. Deattach finisher. Ensure paper path is clear at the exit (use a flashlight and magnifier). Reattach finisher - ensuring all connections are secure. Do you have an error code?
Mar 02, 2015 | Xerox Office Equipment & Supplies
Xerox 7300 paper jam A 10 error code jam telling me to open top tray and I've looked at the machine inside out and cannot find any scraps of paper or any location where there is any traces of paper being...
There is most likely a small piece of paper in the rollers take out Tonor and any parts that will come out with out having to use any tools. then spray with a can of air in all the rollers.
Chris Thrash
Jan 10, 2011 | Xerox Phaser 7300DN Laser Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Sharp 5316 showing paper jam sign at right door but no paper
Shut it off, wait 30 seconds, turn it back on. If the path IS clear, the error will be gone.
Feb 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error message shows e2 but there isn't a paper jam anymore
Hello sir; try to turn off the power and turn on, if still don't work, you have to check the sensor it located where the paper got jam,
Jan 10, 2009 | Xerox WorkCentre XD120f Copier
Paper jam 11
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
