I need to know where the low pressure hookup is to add freon into my 2003 lincoln aviator
  • 6,674 Answers
Low side is normally the larger hose & tubing of the 2 . Larger diameter .
Posted on Jul 26, 2009
I have a Lincoln aviator 2003 my driver light flashes
Lincoln Aviator drive light flashing Questions & Answers ...
www.fixya.com > ... > drive light flashing > Cars & Trucks > Lincoln
Lincoln Aviator cars & trucks drive light flashing questions and answers. ... 2003aviator check engine on why? car has brand 2003 aviator check engine is on ..
Aug 24, 2015 | Lincoln Cars & Trucks
How to jump ac compressor
Well, I will tell you that the electric plug that is on the low pressure A/C switch will engage the compressor clutch when you put a jumper wire in the electric plug. This is done sometimes to draw in Freon to charge the system and then eliminated when there is enough Freon pressure to cause the low pressure switch to work again. Then the pressure switch will cycle as Freon pressure builds.
In no manner should any attempt be made to operate (drive) the vehicle with the switch bypassed as it will destroy the compressor and possibly melt the serpentine belt and parts will go flying. IF the system is low on Freon after 9 years a boost of Freon with sealer will help.
You need some tools with a pressure gauge for A/C. The ideal amount of Freon is what the manufacturer shows on the A/C label plus oil.
There are other tools like Vacuum pumps which take the moisture out of a system. If the system is not empty, you may be able to add Freon. Read up on this more.
May 09, 2015 | 2005 Lincoln Aviator
How do i reset the chime warning very low tire on a lincoln aviator 2003
most often refill tires to spec (35psi) make sure all tires are same pressure then must drive at 40mph or faster til light or chime goes off
Sep 08, 2014 | 2003 Lincoln Aviator
My 2003 Lincoln aviator low pressure light and oil light is on,what does that mean ?
Time to correctly inflate the tires and bring the oil level to required level.
Mar 28, 2013 | 2003 Lincoln Aviator
Where to add freon to 2000 lincoln towncar
low pressure fitting smallest of the two located on low pressure side of system
Apr 03, 2011 | 2000 Lincoln Town Car
My a/c keeps cycling off and on
Sound's like low on freon, the low pressure switch will do that when low on freon, so that your a/c compr. don't get damage due to low freon, have it recharge and check for freon leaks.
Jul 05, 2010 | 2004 Lincoln Aviator
How do I add refrigerant to a 1992 Lincoln Town Car
you can get a kit from napa - bottle and attachment with hose and directions. but first you need to find where the leak is.
Jun 27, 2009 | 1992 Lincoln Town Car
Replace passenger side low beam bulb in a 2003 lincoln aviator
Open hood and remove the radiator site shield and the air delector on top of the headlamp assembly. You will then see 2 clips that you will pull up and then remove the headlamp assembly.
Apr 11, 2009 | 2003 Lincoln Aviator
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
