Question about Hotpoint Washing Machines
Hotpoint Aquarius WDL520P/G/A/K Wanting to know where fluff trap is & how to empty it pls.
SOURCE: Fluff left on clothing
Maytag Performa Washing Machine!!
All our clothes are being ruined with continuos fluff sticking to items.Have tried hot wash -no clothes, same problem.
Have tried not using Fabric Softener still no solution.
guest
Posted on Feb 11, 2008
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: Tumble Dryer-empty water light won't go off
remove panel on rhs looking from back and you will see a chamber with a microswitch on top. either micrswitch is stuck, pump faulty or a lint blockage
Posted on Jul 23, 2008
barkencoa
  • 3463 Answers
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Posted on Jan 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Posted on Jan 13, 2009
I have a new hotpoint Aquarius and has not been used and the clean filter and empty water light is coming on How do I resolve this
The empty tank & clean filter light will come after EVERY use of the machine,
because it is reminding you that this is what the user manual tells you that you're supposed to do EVERYTIME you use the machine.
If the machine breaks down because it's full of fluff, it may invalidate your warranty & a water tank with just a little water, is a lot easier to empty than a full one.!
Mar 10, 2018 | Hotpoint Washing Machines
Where can I locate the tumble dryer condenser and fluff filter for my hotpoint Aquarius extra WD64
from hotpoint web page spares
from you local hotpoint service agent spares section
Jan 28, 2017 | Hotpoint Washing Machines
MY WASHING MACHINE WON'T FILL ALL LIGHTS WORK
I had a very similar problem with a WDL520p, it turned out it was the top display board that had a fault, I bought one on EBay for £12, and the machine is still goin 8mths later.
Nov 15, 2014 | Hotpoint Aquarius WDL540P White 60 cm...
Where is filter on my hotpoint aquarius wmf540 washing machine, im getting white fluff over all my clothes everytime i put a wash on, im guessing the filter needs cleaning and just wondered where it is
http://laundry.manualsonline.com/manuals/mfg/hotpoint/wma58_wma56_wma54_wma52_wma50_wmm59_wmm53.html?idRes=599752
see last page.
also, you should try run a cycle without any clothes (add a bit of bleach) in it in cold water for once to rinse out the dirt.
Oct 02, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where does the fluff go when you use the dryer on
The lint should go in the lint trap. If it doesn't go in the lint trap it goes out the exhaust pipe if the lint trap is not installed.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a Hotpoint Aquarius dryer TDC30. The 'Empty Water' light stays on even though the reservoir has been emptied. The machine runs but does not warm up. Is this a common problem? has the element...
Float chamber is bunged up ,at the rear of the dryer at the bottom is a black plug / cap pull it off and stick a pipe cleaner
or long cable tie metal coat hanger in it to clear the old wet fluff (have some kitchen roll handy as some water comes out with the wet fluff),
other wise its a total strip down to clear the chamber out.
Oct 29, 2008 | Dryers
Wd63 does it have a filter to empty for the dryer!?!
Hi there sarah
The hotpoint washer dyrer does not have a filter for fluff
100%
Need any other help dont hesitate to ask
Jan 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
18 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
