Turn power on, the standby light only blink but there is no picture on screen
SOURCE: Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Posted on Jul 15, 2008
SOURCE: Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Posted on Oct 28, 2008
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
  • 285 Answers
SOURCE: standby blinking no picture or sound
Ok. I think you'll need an IC or a PSU.
Posted on May 24, 2009
SOURCE: red light 5 blinks
Standby light blinks 5 times in sequece is a lamp driver error. Check the lamp first but likely this is the power supply block or ballast as they are called. Replace the ballast.
Posted on Aug 12, 2009
Why no picture?
Probable power supply failure
Apr 14, 2016 | Insignia Televison & Video
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
What would cause your power button light on the monitor keep blinking and the screen is black and you have trouble getting the light to stay on and get the picture back on. what is the problem. thanks,...
If the button on monitor is blinking, it means your computer is either turned off or in standby mode (or in hybernation).
You should push the power button on your computer to restore it from standby (or hybernation).
Aug 09, 2009 | Acer Computers & Internet
Standby red light just continuesly blinks, no picture -
TV TURNS ON 1-2 SEC SCREEN SHOWS COMPONENTNT1 AND TURNS OFF WITH A POP SOUND FRO9M SPKRS
May 17, 2009 | Akai LCT2701TD Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
