Question about Fagor Dishwashers
I have bug on washmachine fagor fch 850, light the buttons start and stop, recconect to site have zero success
My Fagor dishwasher won't fill.
Check the water in-let electrovalve, could have dirt or the coil damage
Apr 30, 2014 | Fagor Dishwashers
Setting the gage for fagor pressure cooker
The Fagor electric pressure cooker does not have a gauge that needs to be set. Instead, it has a handle that has to be turned to point to "PRESSURE" before the electric cooker can start cooking.
Then, you either press "high" or "low" pressure button on the control panel.
You can find detailed instructions in the manual, here:
Jan 28, 2014 | Kitchen Appliances - Others
My washmachine keeps stopping in the middle of a cycle.
Mine does the same thing. Most times I can hit the start button and it will continue. Some times I have to cancel and start over. Under warranty, about to call and see what they will say.
Dec 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zero wireless configuration has been disabled on presario
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
Jul 29, 2009 | HP Computers & Internet
Fagor hob touch control
Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
Jan 28, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Dishwashers Logo
Top Fagor Dishwashers Experts
ray gallant
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
