Question about Samsung Washing Machines
My samsung 13kg toploader has red flashing drum light after every wash cycle. It ends cycle but light continues flashing. What could be the problem
SOURCE: Normal wash flashing Red
We have the same problem with kenmore model 66513839k600
we press light wash and normal wash lights up, we have to wait over a month for sears to service. This will be the second control panel they will install on warranty, a month is far too long a wait for service on any appliance.
Posted on Jan 12, 2008
SOURCE: I have a Samsung SW60ASP
To overcome the problem, try using hand hot water for your wash once or twice each month, the hot water keeps the inside of the machine clean by not allowing the oily residue from body oils that adhere to your clothes from sticking to the hose etc, also there is always some water left over in the bottom of the bowl (you can't see this water) which has left over scum that has not rinsed away still sitting in this water. GIVE YOUR WASH AN EXTRA DEEP RINSE WHEN THE CYCLE FINISHES.(just turn your dial to where it says RINSE) that way your clothes will be much cleaner and the washer will have removed any left over gung etc from your clothes and bowl etc.. Hope this helps..
Posted on Aug 19, 2008
SOURCE: END OF CYCLE KEEPS BEEPING WHILE WASHING
Maybe the machine is telling you that your load is uneven, When going through a spin cycle it will detect if the load is too heavy on one side. Just open the door and spread the load evenly. good luck.
Posted on Jan 26, 2009
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
heatman101
  • 43501 Answers
SOURCE: Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 05, 2010
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
Samsung ecobubble 7kg red drum flashes at end of cycle? Is it broken?
We have later model and have same flashing drum symbol. You need to perform an ECO DRUM CLEAN cycle.
1. Press power to turn on machine.
2. Turn cycle selector to ECO DRUM CLEAN mode
3. Press Start/pause
Mar 01, 2015 | Samsung Washing Machines
Where to clean filters on Samsung 13kg top loader?
Sounds like you need to have your machine looked at by a professional. You should not be finding rubber pieces in the machine.
May 08, 2014 | Washing Machines
Hi, I'm using Panasonic Aquabeat NA-F130T1.(13kg),Fuzzylogic,Toploading. It stops at end of wash mode before rinse and blinks U12 code. Pls advise? Thanks.
Hi there, I'm using Panasonoic F130T1 washing machine.
my problem is,the washing did'nt complete n the water remains in the machine.
Pls advice as how i could solve this problem,tq.
Azhari.
Jan 11, 2013 | Washing Machines
I have a samsung 13kg diamond drum toploader, my problem is after selecting all relevent options to wash my clothes when the machine start washing the clothes it also drain some water out. My clothes end...
If the drain hose is pushed too far down the drain pipe, it will have a tendency to to siphon out. Only use 1 or 2 table spoons of detergent as the washer uses very little amounts of water. Read your instruction manual as it says the drain hose has to be higher than a certain height before it goes to the drain.
Oct 16, 2010 | Washing Machines
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Samsung SW60ASP toploader and it continues to deposit black 'bits' in the washing machine after use, staining clothes and I have to wash everything again. I have had the drum cleaned, but the...
Jul 15, 2008 | Samsung Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
