Question about Facebook Apps
I can't get my Scrabble back on Facebook - Facebook Apps
I live in Spain, and play Scrabble, on facebook, with my daughter in the U.K. If I open facebook with Google Chrome it will not load Scrabble at all. However, if I go from Internet Explorer, to facebook,...
Perhaps your computer needs more RAM to handle this application? As games and apps are improved and upgraded, sometimes they are not optimized for slightly older computers. You might consider upgrading to see if that is the issue. GOOD LUCK!!
Aug 05, 2013 | Gamehouse SCRABBLE® Worldwide excluding...
I am not able to down load scrabble world wide exc.US and Canada
I AM NOT ABLE TO DOWNLOAD SCRABBLE WORLDWIDE ON MYMY KINDLE FIREFOX
Mar 04, 2013 | Gamehouse SCRABBLE® Worldwide excluding...
Scrabble Wlrdwide not loading
Perhaps your computer needs more RAM to handle this application? Consider upgrading to see if that is the issue. GOOD LUCK!!
Feb 07, 2013 | Gamehouse SCRABBLE® Worldwide excluding...
I'm playing yr Scrabble via Facebook, and the screen does not sit in the correct position for me to see all the squares. It did for months, but something has happened.
The setting on your computer probably need tweaking, but hopefully you have solved this problem by now. It may have to do with the resolution of your monitor. Good luck!
Sep 28, 2012 | Gamehouse SCRABBLE® Worldwide excluding...
How to delete scrabble games
Well, you can easily close down your accounts from settings where they will check your authority and permission to shut down account. http://blogmybrain.com/scrabble-cheat/
Apr 29, 2012 | httpwww.WordGamesCentral.com SCRABBLE...
All my games on facebook work except for scrabble worldwide,what can the problem be??
Perhaps your computer needs more RAM to handle this application? You might consider upgrading to see if that is the issue. GOOD LUCK!!
Jan 31, 2012 | Gamehouse SCRABBLE® Worldwide excluding...
Hi, is there anyway i can play facebook scrabble without going into facebook
Set up an account directly in Gamehouse and play from there... good luck!
Feb 18, 2011 | Gamehouse SCRABBLE® Worldwide excluding...
Facebook scrabble loads at work but not at home when the loading always gets cancelled!
If you're using internet explorer, go to "Tools", then "Internet Options", then to the advanced Tab. At the very bottom under "Reset Internet Explorer Settings" click on the "Reset" button.
Reboot. Voila......Facebook Scrabble works again (and other games too!)
Feb 05, 2010 | Facebook Social Network
Facebook Apps Logo
32 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
