Question about Uniden Lands Phones
Have a uniden dect3135+1 and cant delete personal msg recording
I have purchased the Uniden 6.0 and would like to install my voice mail but I am directed to the DETAILED OWNER'S MANUAL which is not in the box. Is it possible for you to download the information for me?...
There are a number of Uniden DECT 6.0 phones. The user's manuals are available from the list here: http://www.uniden.com/index/manuals_results.cfm?cat=59 . Select your model and language for the appropriate PDF.
For the Uniden phone I know, you can set up the answering machine from a handset or the base unit. First turn on the answering system. On the base, press Ans On/Off. From the handset, press either the Phonebook or Redial buttons and use the menu to choose AM Operation. Then select Menu/OK. (Then find Answer On/Off choose On or Off and press Menu/OK to save.)
To set the Outgoing Message, use the handset as above but select Record OGM. (Alternatively, you can delete or hear your outgoing message.) To record the message press Menu/OK and wait for the beep before starting your message.
Next you can set the length of the message recording for incoming calls (1-4 minutes or Announce Only (no messages recorded). Choose Msg. Length from the menus.
I hope this helps.
Nov 15, 2010 | Office Equipment & Supplies
Hi i recored 1 msg when answering system is on now i want todelete that msg how can i delete that msg
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Oct 01, 2010 | Uniden DECT 6.0 Cordless Phone ID
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Recording a Personal Greeting
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Selecting a Greeting
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
Deleting Your Personal Greeting
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
May 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
Recording a Personalized Greeting
Press and hold greeting... it will ask for a new greeting... Record new greeting and then press greeting button again.
Feb 25, 2010 | Uniden 5.8GHz Cordless Phone
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the
messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the
system is in the command waiting mode.
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded
greeting plays back for you.
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Feb 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
Charge light keeps blinking This light usually blinks when we have a recorded msg but there is no msg
I have a problem for my uniden phone. I did deleted msg on uniden phone but the light still blinkling . I don't know why ? . Can you help me,please ?
Nov 22, 2009 | Uniden Lands Phones
Cannot set up voicemail on a Binatone 1210 DECT
Please follow the below mentioned process:
1)press menu
2)press up/down to tam
3)press ok
4)It will say play(press ok to play messages), or press up/down till delete all
5)press ok it will say confirm
6)press ok this will delete all messages. If you want to record your own message follow steps 1 to 3 then 4)up/down till ANS MODE press ok,
7)scroll up/down it will say, ANS ONLY or ANS + REC,
8)select ANS + REC, press ok,
9)it will now say PERSONALIS(your own personal message) or PREDIFINED(standard answerphone message), select PERSONALIS press ok 8)now it will say PLAY MSG scroll up/down it will also say RECORD MSG, press ok hold phone to your ear till you hear a beep, record your personal message then press ok, if you go back to step
10) you can hear your message.
In normal mode, Press and hold 0 key to turn on/off answerphone and your personal message will be on.
To delete messages press 2 key for 2 seconds as messages are played press 6 to delete, you can delete messages before or as they are playing without listening to whole message.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 17, 2009 | Lands Phones
Record personal greeting - how?
Follow the instructions beginning on page 25 of this manual.
Aug 20, 2009 | Uniden TRU8885 Digital Answering Machine
Answering machine not picking up calls
same here. the personal greeting plays whenever someone calls but there is no beep after the recording and then people can't leave msg :(
Nov 21, 2007 | Uniden Cordless phone EXS9950
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
