Question about Electrical Supplies
Onan rv qg 4000 evap timing and valve adjustment broke valve spring and need these specks
SOURCE: Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Posted on Dec 02, 2008
joboo1
  • 257 Answers
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Posted on Mar 02, 2009
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Posted on Apr 30, 2009
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
Valve adjustment for onan 7000 generator
What is your question specifically? how to adjust them? how to turn the engine over? Be more specific
Aug 26, 2014 | Onan Cummins 7.0 HGJAB-6756 RV QG 7000...
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
How to fix onan 4000 that will not stay running
Check the slips rings and brushes, check the stator and rotor windings for continuity and for shorts to ground. Check PCB plug connections. After that you need a new control board
Jan 07, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Sensor de aceite de un onan cummins rv QG 4000 generator 4000w
If it runs while start button is pressed but stops when you let go?
Check the rotor bruhes, slip rings are clean on the rotor. If you want to get deeper check and ohm the resisitance of the rotor, and stator both for continuity and ground shorts. Check plugs and wiring on control board. Failing that replace control board
Nov 18, 2012 | Onan Cummins RV QG 4000 Generator, 4000W,...
Oil is being pulled from valve cover to air filter on my onan microquiet 4000 generator, what do I need to do?
63525c2e-e749-4a53-8402-d0463bb6c753.jpgThat sounds like the reed valve sticking or dirty.
You will need to take out the reed valve, clean and re-install. Be aware that a small amount of oil is common, also do not over fill the oil. The full mark is hot. Too much oil in the crakcase can build up pressure and keep the reed valve open.
Aug 22, 2012 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
