Question about BIT Garden
New husq ride on mower ts323 sound body to body shrinking sometimes if bush brake in tiny bit it stops
SOURCE: cuts out and stops sometimes after 30 min. or so
check your fuel delivery system. It sounds like a blocked filter, failing pump or a restriction in the fuel line.
Posted on May 09, 2009
  • 155 Answers
SOURCE: My Husqvarna riding mower knocks when it is in
This can cost quite a bit, The easiest & most cost effective way is what they call a short block this is the main engine all you do is put all the outside parts off your engine onto it. These can cost from $800 upwards depending on what size your engine is.
Posted on Aug 04, 2009
  • 60 Answers
SOURCE: brakes dont stop and trans dont want to shift unless you killn it
have you replaced the belt recently? try slacking tension on the belt.
Posted on Aug 12, 2009
  • 454 Answers
SOURCE: scotts 1642 riding mower take foot off brake engine shuts off
Sounds like the safety switch in the seat is bad or disconnected. Look under seat to see if anything is unplugged.
Posted on Nov 05, 2009
SOURCE: My jd stx38 riding mower doesn't go forward or reverse after I re
Check the drive belt but if this is a hydro you probly have a bad trans. Best bet get a new mower.
Posted on Jan 08, 2010
Mandrel pulley on husq mower deck very stiff?
if its a manual blade ingaugement style then it should have a brake system on the blade pulleys
Sep 15, 2012 | Husqvarna Garden
Husq 2348 riding mower blades engage, run for maybe 5 minutes, then disengage on their own
Sounds like your PTO switch or clutch has gone bad. Unfortunately, it is usually the clutch.
Sep 19, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I just purchased the new Husqvarna MZ6128 Zero Turn. Was dropped at home on Sunday.. with the parking brake on and deck in the traveling mode and handle bars in neutral it will start..when returning the...
Read the manual. These so called "problems" are standard safety features that someone should have gone over with you. Sounds like poor salesmanship. When starting the mower the bars should be out and the park brake pulled. Then disengage the parkbrake and pull the arms in to drive the mower. Do exactly the opposite to get off the mower. I just bought one today every model I looked at was like this.
May 24, 2011 | Husqvarna Zero Turn Mower Z5426
The mower gets slower and slower and then stops moving completely. I turn it off for five or ten minutes and it's okay ... occuring more frequently ....
The hydrostat transmission is low on fluid. Check your manual, some of these can be filled...most cannot. If yours can't be filled/doesn't have a fill opening, Husq is going to recommend to replace the transmission (sealed unit). There has been limited success by trying to top off the trans thru the vent tube. This is not a Husq approved repair, and is very slow and tedious. But it is a lot less expensive. Good luck!
Aug 23, 2010 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
No manual for Husquvarna ride on mower model 4140H
Don't know if this helps but the owners manual for my Husq YTH2148
indicates that the transmission fluid is not to be changed, ever. If there is a problem, the whole unit is to be replaced.
These mowers, along with many craftsman rider mowers, are actually made by Roper. Perhaps if you googled around a bit you could get more info relating to service of the transaxle.
Apr 05, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The engine dies once the brake is released
Seat switch is defective, obstructed or otherwise inoperable for one reason or another.
Check this:
Unplug the plastic connector from the seat switch.
If it is ONE SOLID connector, stop right there!
HOWEVER, look into the connector's terminals (not the seat switch's terminals, the tractor wiring harness terminals). If you see a small square divider between the terminals and that divider is a movable, inserted part (NOT an integral part of the connector's plastic body), take a small needle-nose plier and pull it straight out of the connector's body.
BEHIND that removable square plactic piece, locate and remove the tiny torsion spring from between the two terminals. Throw these two parts away and plug the connector back into the seat switch.
Hope this helps.
Oct 04, 2009 | Garden
Cub cadet LT1018 won't start or crank
It might be a saftey problem. But before you start changing swithches or whatever try this. If you have to lift a lever to engage the PTO for the blades try wiggling it up and down a little bit while sitting on the tractor and the brake pedal depressed and turning the key to start it.
Sometimes there is a little wearing and it won't be in the right spot on its own.
Good luck and let me know if this helped.
Aug 07, 2009 | Garden
My Husqvarna riding mower knocks when it is in low. And some times it back fires. I ran it with low oil. Is my Husq shoot? Can this be repaired? How much will it cost? Mr.fellbad.
Jul 22, 2009 | Garden
Garden Logo
18 people viewed this question
Top BIT Garden Experts
Bill Boyd
David Hoover
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a BIT Garden Expert? Answer questions, earn points and help others
