Question about Cell Phones
Lgls675 firmware installation on my cell phone through my computer with a usb
  • Cell Phones Master
  • 515 Answers
No, you have to download your application through online
Posted on May 20, 2017
I am trying to downgrade my galaxy s7 from android 7.0 to android 6.0.1 using my computer. It's model number is SM-G930V.
In windows pc.Download latest marshmallow 6.0.1 firmware. Then download and install samsung drivers. Also download latest version of odin samsung firmware flasher.
1.put device in download mode
Turn off device and wait 3 seconds then press volume down home and power button. Phone screen will flash custom os can cause bla bla bla then press volume up button
You are ready
2.connect your s7 with usb cable (use genuine)
3.wait computer finish installing drivers odin with administrator odin there is com1 or whatever your pc displays blue indicator
6.if you downloaded your phone firmware if has md5 or tar format no need extract if has zip format then you should extract the firmware. pda button and select your firmware. flash start button
9.wait until finish phone will reboot and your phone will be downgraded.
10. If above method not working try another firmwares.
Jan 01, 2018 | Android Cell Phones
Password reset 0000
If you have lost or forgotten the password the the only way out is to re-install the firmware. Run Samsung Kies on your computer and connect the phone to it via the USB cable and follow instructions word to word.
Nov 04, 2013 | Samsung Eternity Cell Phone
How to reinstall phone software by computer
On your computer install Nokia PC Suite and run it. Fully recharge the phone battery. Connect to the computer thru USB cable. In PC Suite backup the data of the phone. remove the SIM and the memory card. Now update the firmware. Follow the instructions, word to word. After some time you will be told that the firmware has been updated. Cheers.
Oct 30, 2013 | Nokia 5250 Cell Phone
How to update mobile os in Samsung champ?
* Download SAMSUNG KIES as your tool,install it on your computer.
* then you need a CA-101 usb cable.
* Be sure battery is fully charge
* Also stable internet connection is required
1. Open Samsung Kies software
2. Plug your usb cable to phone all through the computer.some driver will install on progress or go to tools tub the click install driver
3. Go to tools tub again and select firmware upgrade settings,ne sure the phone is recognized then click ok.
Oct 06, 2011 | Samsung GTC3300 Cell Phone
Block my securite code
Update your firmware using PC Suite.
Tools needed:
Usb cable
1. Download and install a compatible PC Suite for your mobile phone into your computer. You can get it here: NOKIA PC SUITE
2. Insert usb cable to the computer and insert the other side to your mobile phone (must be powered on)
3. Your phone will be detected by the computer and installs the drivers needed and wait till its finish.
4. Open the PC suite and Look for the k4r70.gificon and click it.
5. Wait until its finish updating the firmware of you mobile phone.
I hope this will help you. Good luck
May 30, 2011 | Nokia X3 Cell Phone
I am having Problem while connecting Phone through USB Mode . It is properly connecting with Bluetooth , But as i try to connect it through USB it problems. Because of this I am not been able to update...
The reason for your problem is that you have not categorically set the phone for PC Suite operation in the USB settings.
To do this you must go to Settings->Connectivity->USB. Here you will find four options and one of them is PCSuite mode. All such operations that you want come under this category.
When you want to use it as a drive then select Mass Storage and then only will your phone be visiblle in My Computer as an additional drive.
Jan 24, 2011 | Nokia N72 Cellular Phone
I installed the newest firmware on my PC, started ...
I installed the newest firmware on my pc started the download process until I moved the usb cable and the phone powered off and would not power back on.
May 21, 2010 | Nokia N73 Cellular Phone
Cant upgrade software
you can download to pc or directly to cell (as long as you have an unlimited data plan) firmware to pc is just as connect the cell via usb cable to pc.....(make sure your cell phone connection is switched to data) find the cell on pc (my computer) open it you should see data and extract the firmware and place it there ...disconnect power down cell / up again to see if firmware was taken
new free firmware
May 19, 2010 | LG KM900 Arena Cell Phone
Want to install firmware withouting usb cord
First thing to do is backup what is on your PSP, take the flash memory card out and connect to your PC.
Try this if you have luck you can.
Kindly rate my help+ Thank you
May 10, 2010 | Sony Ericsson G502 Cellular Phone
Nokia 1650 Firmware Update
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Updating Nokia Mobile Phone Firmware Here I’ll tell you the things you need to do in order to update the embedded firmware in your Nokia cell phone.
Things to do before a firmware update:
  1. Install Nokia PC Suite, and back up all the stuff from your phone to your computer.
  2. Charge your phone battery to its full level.
  3. Beware that any hindrance (like power off, etc.) during the update process can damage your phone.
Let’s get started.
  1. In your Nokia mobile phone, type in *#0000#
    Your Nokia mobile will now display the firmware version it’s running
  2. Carefully open the back case of your mobile, and also take away the battery.
  3. Note the product number down
  4. Go here and type the product number. You’ll now know if a new version of firmware for your Nokia mobile phone is available
  5. Download the Nokia Software Updater. Click here to download it
  6. Install the Nokia Software Updater (I think it’s recommended to run it if you have more than 256 MB of RAM on your computer)
  7. Connect your Nokia mobile phone via the USB port, and also make sure your computer is connected to the internet
  8. Run the Nokia Software Updater by clicking on the icon on your desktop
  9. The Nokia Software Updater connects to the internet, checks for updates, and then detects your phone to start installing firmware updates for your Nokia phone
  10. You might see some fuzzy things going on in your Nokia phone, and that’s perfectly normal to happen during a firmware update
  11. When all’s done, the updater gives a confirmation message and then the phone restarts
  12. You can now disconnect the phone from the computer
That’s how you upgrade your Nokia mobile phone’s firmware. Let me know in the comments if you have any question.
Oct 21, 2009 | Nokia 1650 Cell Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
