Question about LG Washing Machines
Me and my kids are going nuts because everytime we wash something, it goes off balance the clothes are wet and it flashes ue ''uneven'' even if it is only 1 piece of clothing . I have adjusted all the legs several times to make sure it's balanced, however the drum will wobble and the cycle will not finish. I have to remove some things and hang dry them . this sucks any suggestions other than pithhing this in the garbage?
    Sergeant:
  • 399 Answers
If the cycle does not gets complete then its --
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Jul 25, 2009
Why does the UE come on ,on the cleaning cycle
The UE error or fault code indicates that the load of clothes is unbalanced. Try rearranging the clothes. Also, if you are only washing a few items, you may need to add a few more to allow the tub to balance. Also, check to be sure the machine is level and that all four feet are touching the floor. Tighten the locking nuts on the feet to lock them into place. If that doesn't seem to be the problem, either the suspension rods or shock absorbers may be broken or worn out.
Aug 25, 2014 | LG WT5101HV 4.5. CU. FT. ULTRA CAPACITY...
My waching maching is not completeing its cycle. The ue code appears when the cycle comes close to the end. We took all the clothes out and tried smaller loads to balance it out better, but nothing seems...
There is a sensor in the back of the washer that senses your load. Truthfully the less in a frontload the harder it is to balance itself. If you get the uneven load error your sensor is probably going out and will need to be replaced. If you pull the washer out it should have an access panel in the rear. Look on the right side of the tub in the back after the panel is removed and you should see the sensor hanging off the side with wires going to it. If I had a model I could probably get you a part number.
May 25, 2011 | LG Washing Machines
When water drains and machine goes into spin cycle it starts to make a loud clonking noise. It sounds as if the drum is going to fly out of the machine.
I've experienced this on occasion. stop the washer, redistribute the clothes, etc. so it is evenly balanced. The "rocking" occurs when the balance is uneven.
Apr 10, 2011 | Kenmore Washing Machines
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Oct 28, 2009 | LG Washing Machines
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
Error message UE
out of balanced? adjust your clothes till there even around the bowl. set the machine on a higher water level. cheers
Mar 31, 2009 | LG Washing Machines
UE error code
You may have a problem with the ball balance sensor.  One of the things I have noticed is when the installers deliver and set up the washers, they get a little too rough and cause a dent in the rear panel of the washer.  In the rear panel, the ball balance sensor is mounted onto the frame.  If the tub spins too wildly, it will hit the ball balance sensor causing it to go UE.  But if the back panel is pushed in too much, the tub will actually make contact with the ball balance sensor too early causing a UE error code.  You will need to have a qualified LG technician look into it.
May 07, 2008 | LG WM-2277HW Front Load Washer
LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
Jan 09, 2008 | LG WM2077CW XL Front Load Stackable Washer...
Washing Machines Logo
119 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
