Question about Troy Garden
I have a troy bilt self propelled mower and it wont start i put a new plug in it and it gets spark it has gas and oil there is no promer for this type push mower what could be my problem?
  • Master Hess
    Master Hess May 20, 2017
    Your not getting fuel,be sure to chock it and if it still want start pull your carb and give it a good cleaning.
    Top Expert:
  • Troy Master
  • 49,253 Answers
Use the choke lever
Posted on May 20, 2017
My lawn mower fires up but idles slow and rough
No adjustments. Automatic governor. Replace spark plug. Ensure blade is sharp and oil is full. 30w oil. Always put Stabile in gas. When you remove spark plug pull rope several times to blowout cylinder. Spray a little WD40 in spark plug hole, then pull rope several times. Spray starting fluid in spark plug hole, replace plug, ensure plug wire snaps on tight. Clean replace air filter.
Aug 09, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Where is the oil change plug
The plug is under the mower on the bottom of the engine. Make sure you take the spark plug wire off before you work, remove the blade (it needs sharpening anyway right?) and then tilt the mower on its side WITH THE CARBURETOR UP. position an aluminum cake tin under the mower so that once you remove the oil plug using a 3/8" ratchet you can set the mower back down over the cake tin and it will catch the oil. Don't forget to put the plug back in =-)
Jun 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
23 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
