Hot point Aquarius wmf740 error code f06 please can you help
  • 55 Answers
SOURCE: Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Posted on Feb 12, 2008
SOURCE: my aquarius hot point fdw70
Check out www.selfix-uk.co.uk for all hotpoint error codes and what they mean
Posted on Oct 07, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
  • 1525 Answers
SOURCE: error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Posted on Mar 22, 2009
barkencoa
  • 3463 Answers
SOURCE: Error message F-01 & flashing lights etc
Error code F01 indicates a short circuit motor triac.
You need to check connections on the motor, the motor plug and the module.
Having said that, you really should ring the manufacture, as the washer is still obviously under guarantee, and should be fixed at no cost to you.
The point to bear in mind is that if you do anything to it yourself, then in theory, you could invalidate the guarantee.
So, unless it is anything obvious, then I would advise you ring the manufacturer.
Hope this is of assistance to you.
Please rate my solution.
Thankyou.
Posted on Dec 21, 2009
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Could someone email me the fault codes for a hotpoint aquarius wmf740 washing machine please
Hi I see you need the Fault Codes for your Hotpoint Washing Machine
See this link for the info since I do not have your E-mail to send the details I have created this link for your viewing regarding your concern.
Hope this helps.
Oct 02, 2012 | Hotpoint Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint aquarius wmf740 that is showing a fault f--5 and wont empty out the water
Something wrong the pump would prevent the machine draining and generate an F5 code.
http://appliancejunk.com/ge/washer/31-9103.pdf
Service manual above.
Jun 25, 2010 | Washing Machines
My aquarius wmf740 has a blockage cannot undo the white water release valve on front bottom right hand side of washer to solve problem. Any help grateful.
tip machine right back and unscrew valve. It is probably caught on something. Hope this helps ( I had a kirby stuck in mine)
Audrey
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The machine won't start as saying door isn't
1.the door may be worn at the point it presses the switch at 2.the door switch may be wired incorrectly 3.the door switch may be worn out and needs to be replaced
Mar 06, 2010 | Washing Machines
Error message F-01 & flashing lights etc I have a Hotpoint aquarius, WMF740. Suddenly returning to the kitchen I noticed an error message - the machine was switched off - which says F-01 and flashes...
Thankyou.
Dec 21, 2009 | Hotpoint Washing Machines
Hot point aquarius wf740
Hi.
F03 indicates that the wash thermistor is open or short circuit.
I think you need to call engineer to sort the problem
Please leave feedback.
Dec 02, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
