Question about Elna Sewing Machines
Elna 680 book does not show the place to oil the machine
  • Elna Master
  • 11,774 Answers
The newer computerized models do not require the oiling that the older mechanical models need. If the manual does not specify oiling your machine, then you should probably not oil unless advised by a qualified technician.
Posted on May 20, 2017
Oil or not an Elna 6600 quilters dream 2 ?
Since it is a computerized machine, oil as directed in the manual. Oiling in the wrong place could damage the machine.
Jul 20, 2017 | Elna Sewing Machines
What type of grease do I use on my elna 305 sewing machine.
NO grease!!! Best option is to pick up sewing machine oil sold by Elna--make sure it is the oil recommended for your model. For a computerized machine, apply only as directed in the owner's manual. Computerized machines usually take a clear, thin oil whereas mechanical machines usually take a thicker, lemon-colored oil. To keep your machine purring, AVOID old or inexpensive sewing machine oil. If it is an older mechanical machine, a drop or two can be applied every place where metal rubs against metal--do NOT oil nylon gears, belts, etc.
Jun 13, 2017 | Elna Sewing Machines
2110. Why doesn't the flywheel move?
Consult your owner's manual--the Maintenance and Troubleshooting sections. Have you oiled it as the manual suggests? There are several suggestions of what to check if your machine does not operate.
If you need a manual, here is one available:
ELNA 2110 Instruction Book
Oct 22, 2015 | Elna Sewing Machines
When, where and with what do I oil our Elna 6200 sewing machine?
Refer to your manual as to oiling your machine. Some computerized machines do not require oil. By all means, do NOT use 3-in-1, WD-40, or cooking oil on your expensive machine. Use a good quality sewing machine oil if you want it to last.
Here is a manual for download if you need one:
ELNA 6200 Instruction Manual
Jul 11, 2015 | Elna Sewing Machines
How to wind a bobbin on a 2004 elna sewing machine?
1 - Look in your book.
2 - Ask a sewer to show you.
3 - Google
Jul 16, 2014 | Elna Sewing Machines
Where do I oil my elna 2007
This image shows that you need to oil the needle bar bearings and the rotary hook area. Also, always brush clean the rotary hook area after each use as keeping lint ouf of moving metal parts will prolong the life of any sewing machine and let the oil do its job.
Also, use good quality clear sewing machine oil, just a drop in the points indicated.
Feb 07, 2011 | Elna 2007 Mechanical Sewing Machine
How do I oil an Elna 1010? Instruction manual says to take cover off and oil where arrows appear on illustration. But there is no illustration that shows this inside the machine after cover is taken...
For oiling the machine you need to look at the picture on the link below. The oil points are the red arrow.
Or you can get the manual on the lin kbelow page 35 will show you.
http://www.scribd.com/doc/3714472/Elna-1010-Manual
Good Luck
Nov 01, 2010 | Elna 1010
Would like toknow how to clean and oil my elna 1010
page 34 shows some oil use.
older models have a "red dot" to show you where to put 1-2 drops of oil per month (depending on your use)
Jan 26, 2010 | Elna 1010
Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Jul 05, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
52 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
