Question about Samsung Washing Machines
My Samsung wa10u3 washing machine on start up sounds like it is in spin mode. on opening the water, the water drains immediately. selecting a program it starts but the water runs out.
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
SOURCE: washing machine
wont spin
Posted on Dec 08, 2007
  • 25 Answers
SOURCE: my Zanussi zwx1605w
norm faulty heater/element iff not faulty pcb
Posted on Jul 13, 2009
  • 44 Answers
SOURCE: Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Posted on Jul 30, 2009
beltronic205
  • 1467 Answers
SOURCE: I have purchased SAMSUNG -
sounds like the drain pipe is too low resulting in Syphoning of water lift pipe above 24 inch floor level, this should cure...
Posted on Feb 01, 2011
How do i fix my washing machine,it only drains water instead of washing clothes.
call a service technician as it may be a faulty program board
Nov 20, 2015 | Washing Machines
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Why would the drain pump on an LG top load washer would run continuoulsy?
Yes, that does sound like it is the control panel, as that would cause the machine to do weird random things as you are describing. The part should be available at searspartsdirect.com or my favorite, easyapplianceparts.com. Just type in the model number of your machine and diagrams, parts and prices will appear. Good luck, Dennis Wayne
May 13, 2014 | Washing Machines
Bosch classixx washing machine over fills, stops for 5 mins,drains water and stuck on rinse without doing the wash cycle. it spins when spin cycle is manually selected.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 25, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Samsung washer wont spin
Check this link for tips;
Jun 28, 2012 | Samsung WF337AA Front Load Washer
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
I have a samsung washer machine and it fill up then stops and an error code de comes up and an alarm sounds and it stroped working
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Aug 08, 2011 | Samsung Washing Machines
Hi my washing machine samsung WA10U3 top load. After wash always filter check. Why?
because the function of filter is to block the small particles or dirty things including grease or oil etc., before disposing the water, and to avoid the clogging of floor drain and even sewage line. And after you used it you should check the filter if theres a some dirt, and grease or oil to clean up to avoid clogging and unclean water from your washing machine
Feb 06, 2011 | Samsung SW62ASP Top Load Washer
Aug 31, 2007 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
