Question about Vacuums
My shampooer uses to much cleaner - Vacuums
Liquid comes out of shampooer but it isn't sudsy. What could be wrong?
Check the Shampooer Tank seating. Turn the unit off and unplug. Remove the Shampooer Tank and inspect the reservoir for any foreign substance. Reseat tank. Replug and turn on unit. Remember to keep your filters clean. There's the lint filter on the cap of the main tank and there's the Flow Filter (Turn Flow Indicator Cap counter-clockwise to remove, remove rotor, and filter is under it. Clean and replace in reverse.) Bissell Consumer Care 1-800-237-7691 if you need. Additionally check you Use Guide for more information.
Nov 25, 2015 | Bissell Lift-Off Pet Deep Cleaner
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed '
May 01, 2014 | Vacuums
Using Bissel proheat carpet shampooer. Have used
No, you don't dilute it. And yes, it does use a lot of formula!
Apr 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Sep 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
