Question about Aspire Computers & Internet
Aspire z3-105 ...three beeps then three more but computer still will not start....removed the two 4gb cards,cleaned and replaced still no start. Help....
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Remove the CPU and CMOS battery from their sockets and press the power button of the chasis without connecting the power cable for 1.5minutes. After that place the CPU back into its socket and connect the power cable then power on the PC, it should power on and boot. After powering on Setup the BIOS settings and shutdown the computer and place the CMOS battery then you will be good to go.
Posted on May 20, 2017
Three long beeps one long beep when trying to install ram
check your windows version to see if it is 32 bit or 64 bit, the 32 bit version will only recognize 1 4gb module. Also when installing memory upgrades it is always best to use matched pairs to avoid problems. Luckily memory prices are much better than they used to be.
Feb 25, 2014 | Lenovo Computers & Internet
I have an Acer Aspire 5733z when I press the power button the follwing happens; 6 beeps than it pauses another 2 beeps and shuts down. It only shows the start up page and when I press F2 a loud sound...
Hi, Do this for me. Check your RAM memory card(s). If it is bad windows will not run. Reseat the ram card and try again. Try with a new known ram cards. You may need a new card. Good luck.
Jan 22, 2014 | Acer aspire 5733z4851 intel pentium...
Acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one long beep repeated
Remove the side panel and remove the RAM.
Clean the RAM slot with dry brush or cloth.
Clean the RAM.
Fix the RAM back in the slot.
Close the cover and Start the PC
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 13, 2011 | Acer Aspire™ T180 PC Desktop
My computer beeps continuously every time i have it plugged in
Try this suggestion. Turn off your laptop, remove the cables and battery on the pc. Press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop and then turn on the pc. If it still continues to beep with no interruption, it is a problem on the motherboard. I suggest to call Acer and have your computer repaired immediately unless if you know how to reseat the motherboard by tearing down the laptop..
Jul 13, 2010 | Acer Aspire 5735-6694 Notebook
I have an ACER Aspire 9423WSMi
so are you asking why is it not reading it automatically or that it does not read the card? check to make sure the 4Gb SD card is formatted properly so that Vista can in fact read it. hope this helps.
Jan 24, 2018 | Acer Aspire 5610-4648 Notebook
When i start my computer just before it gets to the windows screen it shuts off..what do i do
If you're hearing beep codes like 1 short beep followed by 2 long beeps or 1 long followed by 2 short beeps...these beep codes is for either the video card or RAM.
If you could open the computer, remove the video card and RAM from their slots and clean the gold plates with dry cotton cloth. And clean the slots using a blower to remove the dust.
If that did not resolve the issue, listen to the beep code and consult a technician so that he could tell you which component is defective.
Thank you!
Jan 24, 2010 | Acer Aspire 5100 Notebook
Installation of audiophile 192
Here is a list computer beeps and what they mean.
  • No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
  • One Beep: Everything is normal and Computer POSTed fine
  • Two Beeps: POST/CMOS Error
  • One Long Beep, One Short Beep: Motherboard Problem
  • One Long Beep, Two Short Beeps: Video Problem
  • One Long Beep, Three Short Beeps: Video Problem
  • Three Long Beeps: Keyboard Error
  • Repeated Long Beeps: Memory Error
  • Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next move to a second floor window and, while you explain whats going to happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
Dec 02, 2009 | M-Audio Audiophile 192 Sound Card
My Lenovo T60 will not boot up
ok...and these beeps..do they happen before screen shows anything?
Nov 21, 2008 | Lenovo Thinkpad T60 Notebook
3 long beeps
Greetings,
Clean the memory card terminal, or if you have some extra replace it, or if you have two memory card use the other one then exchange it.
Try to open it again.
Thanks.
Nov 06, 2008 | Intel D850MV Motherboard
ASUS A832-SLI Deluxe Display Errors
neckbeard
remove the memory and gently clean it very well and then connect it back to motherboard. if got long beep then memory damage.(replace memory) if got tree short beeps, clean the video card and connect it after cleaning if got same beeps ( then replace video card) thats only only things. Good luck.
Dec 16, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Computers & Internet Logo
135 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
john smith
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
