Function keys not working etc. add, plus, divide, equal
  • 58 Answers
SOURCE: keys problem
You have primary keys and secondary one. The secondary can be used by holding at the same time shift and the key you want to execute or the by holding fn key and pressing the one you want to press.
Also fn key sometimes is disabled in bios.
Posted on Jan 16, 2008
SOURCE: there is no "plus equal" key!
after add some numbers or minus equal key not show result or not working only show multiple or divide
Posted on Nov 16, 2008
SOURCE: Non functional keys
HP 48SX and HP 48GX calculators have a membrane which connects between the internal circuit boards. This is a common failure point. The "ON" button is often the first button to go out. The calculator can be opened up can cleaned, but it is a little involved. Forutnately someone has posted pictures and information on what to do.
http://www.hpcalc.org/hp48/docs/opening/hprepair.zip
There is a text file with information. The file is big because of the pictures. Summary: Open the case, bend metal clips holding the circuit boards together. Clean up any dust and the contacts. Reassemble.
Posted on Mar 02, 2009
SOURCE: ti 84 plus cannot clear or divide HELPPP!
We had one that did the same thing. The retailer we purchased it from advised us to remove the batteries and put fresh ones in, then turn it back on. Ours resolved itself. Hope this works for you. If not, return it to the retailer you bought it from. Could be a lemon.
Posted on Jul 11, 2012
Testimonial: "I'll try! THANKS!"
  • 102366 Answers
SOURCE: how cani i solve "x divided by 9 and x divided by 9 equals 4
x divided by 9 and 9 divided by 9 equals 4, so x divided by 9 equals half of 4 or 2. 2 times 9 equals 18, so x equals 18.
To check, 18 divided by 9 equals 2. 2 and 2 equals 4.
Posted on Nov 30, 2014
6 divided by 2/3 + 1/2
First add 2/3 (4/6) + 1/2 (3/6) = (7/6) = 1.1666
6 divided by 1.1666 = 5.1431
Oct 03, 2017 | Office Equipment & Supplies
What are 4 different fractions that are equal to 1 1/2
Hi Anonymous,
You can make equivalent fractions by multiplying or dividing both top and bottom by the same amount, but only multiply or divide, never add or subtract, to get an equivalent fraction.
I've only shown the fraction part of your question as 1 is a whole number.
1/2 = 2/4, or 4/8, or 8/16 or 16/32 or 32/64 & so on.
Going the other way, dividing 2/4 by 2 will give 1/2.
But, only divide when the top and bottom would still be whole numbers, for instance you wouldn't use divide for odd number fractions, for example 1/3 or 3/5 etc.
Trust this helps, best regards Alan
Feb 11, 2015 | Office Equipment & Supplies
How cani i solve "x divided by 9 and x divided by 9 equals 4
Nov 30, 2014 | Summit Appliances Division Refrigerators
How can I calculate combinations with fx-991ES PLUS?
Use the combination function. It's the shifted function of the divide key, marked nCr. For example, to find the number of combinations of 9 things taken 3 at a time, press 9 SHIFT divide 3 = and see 84.
May 03, 2014 | Casio FX-115ES Scientific Calculator
Dividing decimals
What is the problem? Enter one number (decimal or otherwise) press the divide by key and enter the second number. As long as the second number is not equal to zero you get a meaningful result. Try it. No special handling is necessary.
May 25, 2011 | Texas Instruments TI-83 Plus Calculator
What is the answer to 10x minus 3x equals 20 plus 1 equals what
joshua,
X = 3 (answer)
Here are the solution steps:
10X minus 3X is 7X (right?)
20 plus 1 is 21 (right?)
therefore:
7X = 21
now divide both sides of the equals sign by 7
7X divided by 7 equals 21 divided by 7
7X / 7 = 21/7
X = 3 (answer)
More math? Ask for Gort007
Thanks for trusting FixYa !
Sep 14, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Dont know how to add or subtract on it
On most calculators you enter operations as you would write then on a line (a single line). This is called algebraic notation.
Say, you wante to calculate 2 +3=?
You turn your calculator on
You clear the screen if is cluttered. (there is a button for that sometines labeled A/C or AC, which stand for Clear All.
You Press the key for number 2 then the key for the plus sign, then the key for 3. You get the result after you press = or ENTER or EXE on Casio calculators. Once you do, that the screen displays 5, the summ of 2 and 3.
Tu summarize (The content of each bracket [] is a key you press.
[2][+][3]= ----> 5 Addition: 2+3=5
[3][x][9]= ----> 27 Multiplication 3 times 9 equals 27
[1][8][/][2]= --->9 Division 18 divided by 2 equals 9
[3][3][-][9]= ---> 24
Hope you will enjoy using your calculator
Sep 01, 2009 | Monroe Office Equipment & Supplies
Program for calculator using vc++
hi, here the code...
class is used for items(item.h) . In this class are stored the two number into property and the result:
property double nr1;
property double nr2;
The operations like :asin,cos,power,pi,plu,divide,sqrt etc. are edited into inherited class from items:
#pragma once
#include "Items.h"
using namespace System;
public ref class asinus : public Items
public:
asinus(void)
double^ asin(double a)
return Math::Asin(a);
In the base class 6 boolean variable is used for the precedent operation:
bool plus;
bool minus;
bool produs;
bool divide;
bool sin;
bool prec;
For button equal:
private: System::Void btnegal_Click(System::Object^ sender, System::EventArgs^ e)
prec = false;
if(plus == true)
this->txtRes->Text = Convert::ToString(p.aduna(i.nr1,i.nr2));
else if(minus == true)
this->txtRes->Text = Convert::ToString(m.scadere(i.nr1,i.nr2));
else if(produs == true)
this->txtRes->Text = Convert::ToString(pr.inmultire(i.nr1,i.nr2));
else if(divide == true)
this->txtRes->Text = Convert::ToString(d.impartire(i.nr1,i.nr2));
there is a function for operaton click:
private: System::Void Operation_Click(System::Object^ sender, System::EventArgs^ e) { if(prec == false) { i.nr1 = Convert::ToDouble(this->txtRes->Text); } if(prec == true) { i.nr2 = Convert::ToDouble(this->txtRes->Text); } }
Apr 10, 2009 | Microsoft Computers & Internet
There is no "plus equal" key!
press the plus key again, it should work. ie put a number in and press the plus key twice, it should double, and again it should double again and so on
Sep 16, 2008 | Casio DR-T220 Calculator
BASIC ADDITION
hi,
I had one that did that. equals turned out to be for multiplying and dividing . try to hit plus( + ) sign again instead of equal for the solution.
hope that helps
J
Aug 07, 2008 | Canon P170-DH Calculator
20 people viewed this question
jasbo
jasbo
