Question about Lands Phones
Red light continually flashing all the time sign indicating message waiting but no message just red light flashing
J Kitch
  • 84 Answers
SOURCE: 8310 blackberry curve
To answer your first question, the green flashing light is the coverage indicator. It will flash green when you have a wireless signal. If you want to disable that then go to Options > Screen/Keyboard and then set the LED Coverage Indicator option to Off.
Posted on Oct 05, 2008
rtrahan
  • 741 Answers
SOURCE: battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Posted on Jan 01, 2009
  • 84 Answers
SOURCE: how do I turn off message waiting indicator light
The VMWI led will stay lit if you have voice mail service from your telephone service provider. A lot of providers will also give a broken or stutter dial tone when you first go off hook as an indication of messages waiting. If you hear a stutter dial tone when you first go off hook, you will need to contact your telephone service provider. If not, you can try a simple reset on the base unit, just unplug it from teh AC adapter for about 5 minutes and then plug it back in.
Posted on Mar 24, 2009
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Posted on Jul 14, 2009
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Memorex Phone model MPH692-red light continues to blink
The light may be a "new call indication" or "message waiting" indication if you have voicemail service from the phone company. If you clear the caller id log or clear the voice message the light should go out. BUT, it will keep coming back on when a new call arrives! I have a similar phone and I just put a piece of tape that matches the color of the phone over the light.
Apr 21, 2010 | Lands Phones
I have a uniden dect1580 6.0 and the red light in the left hand corner blinks all the time.
That is the message waiting indicator, it is telling you that your Call Notes (Or whatever your service provider calls it's voicemail) has a message waiting. If you do not have a message waiting, you can turn the light of by following these steps:
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes and
appears in the handset display. In the event your message waiting light gets out of sync with your phone company’s
voice messaging system, you can manually reset it back to the “No messages waiting” state.
Press and hold FIND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
A beep sounds and the message alert tone is reset.
Jan 21, 2010 | Uniden Cordless Phone
Have no message but red light keeps flashing
The term we used for this back when I worked for the phone company was a "stuck message waiting indicator" and the way to fix it was:
Call yourself and leave a message.
Hang up and wait 2 minutes (we used to say 5 minutes, but 2 is plenty)
Retreive/delete your voice mail message
That should clear the blinking light.
Jul 09, 2009 | Uniden Cordless Phone
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
2005 ford freestar reset light on
Vehicles Without Message Center To reset the system, press and hold the odometer reset button and wait for the "TIRE PRESSURE SET" light to illuminate. Continue to press the button for 3 seconds, then release. After 3 seconds, the low tire pressure warning lamp will flash 3 times, indicating that the low tire warning system reset procedure is complete.
Vehicles With Message Center To reset the system, press and hold the SETUP button and wait for the message center to display "REST FOR SYSTEM CHECK". Then press the RESET button and wait for the message center to display "HOLD RESET TO RELEARN". Press and hold the RESET button for 3 seconds. The message "HOLD RESET TO RELEARN" and the low tire warning lamp will flash 3 times, indicating the reset procedure is complete.
Mar 12, 2009 | 2005 Ford Freestar
Digital phone/answering machine
The red blinking light is an 'event' light, it does not necessarily mean a message is waiting for you, it will also start to flash if you have a missed call.
click 'up' on the round button to show the missed calls list and it will stop flashing, at least it does on mine!
Dec 26, 2008 | Philips CD4451S/05 Phone
Red message light flashing
Feb 12, 2008 | Uniden Cordless Phone
Lands Phones Logo
26 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
