How to operate when child lock - Televison & Video
I have a whirlpool microwave WM1107ADWC and I want to turn off the Child lock. How can I do it? I don't have kids and i want to save time when I use my microwave. Thanks
Child locks on microwaves act as a safety feature to prevent children from getting harmed or from causing other possible damage. The child safety lock does not lock access to the microwave; it simply prevents the microwave from being operated. To remove the child lock press the Stop button three times.
Lock the microwaveIf you wish to re-lock the microwave, perform a similar procedure. Instead of pressing the Stop button you need to press the Start button. Press the Start button three consecutive times to lock the microwave. This enables the child lock once again and prevents the microwave from being operated.
check this video also. Many Whirlpool microwaves are made by LG. between these two you should get it.
How do you remove the child lock on microwave
Jun 12, 2017 | Whirlpool Microwave Ovens
How to turn off child lock of LG refrigerator vth model number GL- 528?we already tried by holding it for 3 sec....it doesn't works at all....nd have a beep sound too
Pressing this button stops operation of other buttons.
"Locking" or "Un-Locking" is repeated whenever pressing the CHILD LOCK button. (For "Locking" or "Un-.Locking" press the "CHILD LOCK" button for 3 secs.)
When 'CHILD LOCK' is activated, pressing the other buttons would not work.
Aug 22, 2016 | LG Washing Machines
My control panel reads loc why want it turn on
child lock is turned on , controls wont operate if child lock is on (safety)
holding down stop for 30 seconds usually on most models turns off child lock
Oct 20, 2015 | Washing Machines
Child safety lock
This is in the design of the window lock. In order for the driver to operate the other windows this switch must be turned off. Windows locked are windows locked. You cannot over ride this function without damaging the system.
Apr 05, 2014 | Honda Odyssey Cars & Trucks
Turn off child lock
Setting child lock
The child lock can be set to prevent a programme being accidentally started or a programme in operation being accidentally changed. The child lock function locks all buttons and the programme knob. The child lock can be activated or deactivated by holding down the OPTION and OK buttons simultaneously for 5 seconds.
  • Before programme is started: Appliance cannot be used
  • After programme is started: Programme in operation cannot be changed
The icon appears in the display to indicate that the child safety device is activated. The child safety device is not deactivated once the programme comes to an end. If you want to set a new programme, you must first deactivate the child safety device.
Dado
Below is Child Lock Icon
Mar 11, 2014 | AEG Dryers
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
Rinnai 431 heater. Power button will not turn unti on. Unit is pluggen in, the child lock will engage and disengage. No other lights (temp lights etc) are on. Checked all connections on circuit board and...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
" If Child Proof Lock is activated during normal operation, then no functions other than the On/Off switch will be operable until the lock is released"
"If Child Proof Lock is activated while the appliance is OFF, then the complete range of functions will be locked"
Oct 12, 2010 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 | GE Ovens
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Child lock
I see, the x hold does indicate the child lock is on.
No buttons work when it is on.
Here are some istructions on turning it off:
The Child Lock deactivates all buttons on the unit and remote
control. Use it to prevent other people from operating the unit.
Press and hold [ENTER]
and [RETURN]
simultaneously until “X
HOLD” appears on the unit’s display.
If you press a button while the Child Lock is on, “X HOLD” appears
on the unit’s display and operation is impossible.
To cancel the Child Lock
Press and hold [ENTER] and [RETURN] simultaneously until “X
HOLD” disappears.
Aug 26, 2008 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
