Question about Lands Phones
As my Joseph Joseph kitchen timer gets to the point below about 5 minutes, it stops running. It can still ring if I manually move it to 0, so ringer is fine. HELP!!!
SOURCE: DRYER TIMER NOT MOVING
you need to replace a t-stat. the one with 4 terminals on it. i believe its the adjustable t-stat
Posted on Feb 04, 2007
  • 21 Answers
SOURCE: Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Posted on Mar 10, 2008
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
SOURCE: Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Posted on Jul 23, 2008
Obertelli
  • 3006 Answers
SOURCE: sigma 70-300 lens will not move in auto mode.
It's almost certainly got a stripped drive gear. This is not a DIY repair, but if the rest of the lens is in excellent condition and not more than around five years old then it's probably cost effective to get it repaired. Sigma are normally excellent at supplying spare parts for their lenses.
Get an estimate for the work from a photographic repair specialist but be prepared for at least a four to six week turnaround time as that's what I'm currently finding for good repair outlets on both sides of the Atlantic.
Posted on Jul 19, 2009
No ring on gigaset phone
1st step check in supply units - 110/230V AC to 9.5V AC adapter for base station.dd
2nd step check in ringer volume (ring tone) if the rank is zero (0) ringer is off and afterward change to wish-able ringer volume 1-5.
Aug 04, 2016 | Siemens Gigaset 4015 Cordless Phone
How can I set time? Lost my instructions
Hold the Reset button, then use Start/Stop to confirm and Min and Sec button to change time
Sep 24, 2015 | Joseph Joseph Clip-On Portable Digital...
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
How to set timer
I found a pdf of the manual for your stove. See the link below to download the pdf.
If you press the button that looks like a bell under the clock you can use + an - keys to set the minutes for a reminder timer that won't turn off the oven.
After turning the thermostat to the temp you want and function knob to the setting you want set the cooking time as follows.
You press the button that looks like steam coming off a pan below the clock for 1/2 second .
Then use + an - keys to set the minutes. Every 12 minutes will make a new segment light up on the inside ring so the numbers corospond to hours on the inside ring.
When the time is where you want it, wait 6 to 10 seconds and the cooking and timer will start.
Smeg A42 5 Instruction Manual
Jun 05, 2014 | Smeg A42-5 Dual Fuel (Electric and Gas)...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
Runs and stop after about 3 minutes
Sounds like a timer. Your timer is sticking
Nov 16, 2009 | Kenmore Elite 21086
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
CHEVY S10 - Once key is ignition won't stop with the ringing nois
I would just disconnect or remove the ringer from the car. Under the dashboard. Listen until you locate it and remove it. They have a timing sensor that is suppose to turn off the ringer after a few seconds. It seems this timer has gone bad. if you replace the whole ringer circuit it may work. But if you have a fairly good memory to take out the key, you can just disconnect the ringer. But it is up to you.
Feb 16, 2009 | 1996 Chevrolet S-10 Pickup
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
