Question about Garden
I have a Sthil chain saw i dont know wot model or year SER, 4960906. can you help please.
  • 87 Answers
SOURCE: I need a manual for homelite chain saw 14" ut no. 10655 ser.
50:1 if you use good oil (i.e.Husqvarna, stihl, echo)
32:1 for lesser quality oil.
Download manual here. have UT# available
Posted on Apr 09, 2009
  • 226 Answers
SOURCE: Can't get the chain oiler to work. Using standard bar oil.
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Posted on Apr 26, 2009
  • 2220 Answers
SOURCE: I need repair manual for chain saw model
Parts and manuals are listed Here:
I didn't see the model you listed, perhaps a typo or an obsolete model. If all else fails try to contact them.
Posted on Sep 05, 2009
Testimonial: "Hey - Just printed out my manual. Thanks. Your service was great!!"
  • 2220 Answers
SOURCE: Remington pole chain saw model 106890-02. Chain
We are in no way connected with RemingtonPower. They are no longer in production and replacement parts are very difficult to find. Often eBay is your only source of parts. Sorry. Lou
Posted on Mar 16, 2010
  • 4088 Answers
SOURCE: Need to know how to
Take the line off of the primer that goes to the tank and leave loose for a moment. The other line to the primer comes from the carburetor and it should be be tried on either port on the primer until it will pull fuel into itself when pumped. If neither port works, the primer pump may be faulty, the carburetor is plugged internally, or the fuel line from the tank to the carburetor is decayed or the fuel filter is plugged. When the primer pulls fuel into itself, reconnect the return line that goes back to the tank. Hope this helps!
Posted on Dec 03, 2010
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
How do I find the model of my sthil chainsaw using the serial number. ser. number is 9258459
Go to
Get the tech support number and give them the serial number, they can look it up and give u the model
Nov 24, 2015 | Garden
How to stop sawdust from coming into the carburetor section and how to adjust the chain oiler. chain seems dry.
Check to ensure the oil opening on the side of the saw housing is not plugged as well as the matching oil groove in the guide bar first. Turn the saw upside down and see if there is a + and a - sign near the sprocket on the bottom. If so, turning towards the + increases flow. Most new small saws oilers are non-adjustable.
Feb 23, 2015 | Stihl GUIDE BAR 16 in STHIL CHAINS
start by turning adjustment screws in. turn low speed out one turn and the high side 3/4 turn. start engine and adjust accordingly. the one turn and 3/4 turn are the starting point. saw should start at these settings and then you can fine tune. without knowing your elevation I can't give you the number of turns .
Oct 13, 2014 | Garden
Iginition coil test for sthil 044
If it makes a blue spark, it's probably good. More orange, probably too weak.
Mar 08, 2011 | Stihl Chain Saw Handle Models 044 046...
I have a Husqvarna Chainsaw, Serial No. 823228. Is it possible to trace the model number?
Sorry it is not possible to tell the model by the ser no., dont know if it is possible to post a picture of it, i could soon tell you what it is.
Jan 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Apr 02, 2009 | Garden
Stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here:
look for part by model number, usually no more than a few dollars. Enjoy
Dec 20, 2008 | Garden
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
