Singer futura ce-200, after applying oil, an error beep signal for every 10 second, how do i fix it
Cannot saw as it's always gives an error beep signal for every 10 second or less.....
  • 23 Answers
SOURCE: Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Posted on Mar 31, 2009
  • 64 Answers
SOURCE: My Singer Futura CE-250 keeps giving me an error
"PC" symbols on the machine panel if it is not connected to PC and switched on is a normal behaviour.
As for communication failure try to remember whether something on your pc has been changed: windows upgrade, machine got connected to another usb port etc. If any of such changes have been made try to reinstall Futura software. Otherwise launch troubleshooting utility and send its report to futura-support.
Posted on Nov 14, 2009
SOURCE: Singer CE-200 Quantum Futura
i need the 2.5 upgrade software for my futura ce200 because i have windows 7 can i download it off the net??
Posted on May 27, 2010
  • 233 Answers
SOURCE: My Singer Futura keeps beeping
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Posted on Apr 04, 2011
armstrong69504
SOURCE: Futura CE 200 Software Installation Media
Yes, from here: Driver Update Software for XP Vista 7 8 Install this software and make the update. Wish you best of luck.
Peter
Posted on Jan 07, 2015
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
Why cant i install futura ce 150 softwRE with windows 10?
Singer Futura CE-150, I NEED HELP!!! - FreeEmbroideryStuff ...
freeembroiderystuff.embroiderydesigns.com/forums/threadView.aspx?id...
Jul 11, 2014 - 15 posts - ‎10 authors
I just got the Singer Futura CE-150 and every time I start a design it ... Posts: 2/10/2014 11:18:44 PM, RE: Singer Futura CE-150, I NEED ... Futura CE-100but didn't realize it didn't have its original install cd with ... I can't afford Singers price. ... -Software-Download-and-Installation_A287.aspx?id=287&siteid= ...
Singer futura ce-350 software download - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesJavaScript isn't enabled in your browser, so this file can't be opened. Enable and reload. ... Singer futura ce 150 embroidery machine 3900 designs dvd. Top 3 singer ... Singerfutura software for windows 10 memphis soft portal. Using my singer ... Singer futura software installation for windows 2000 xp youtube. Service ...
Singer Futura CE-250 Sewing and Embroidery Machine w
SINGER® FUTURA™ Software Installation for Windows ...? 7:20https://www.youtube.com/watch?v=RDkHyrh0ejkNov 30, 2009 - Uploaded by SingerSewingCompanySINGER® FUTURA™ Software Installation for Windows 2000 & XP ... yes i already have a singer ...Singer Futura will not work with Windows 7 - Microsoft Communityanswers.microsoft.com/.../singer-futura.../da1ea4db-8594-4a12-91d1-d8...I bought a Singer Futura sewing machine and a Win 7 laptop for Christmas. ... can find the right person at Singer to talk to they might let you have a pre-release version of thesoftware. ... What if you download the patch and it still doesn't work? ... if you are using ce-150 go to http://futura-support.com/downloads/ce150.html.
Dec 30, 2015 | Sewing Machines
I recently wanted to start using my CE 200 machine and since have lost the software and manual that came with it. Where can I get replacements?
You will need to contact a Singer sewing machine dealer for the software. Make sure it is still compatible with the operating system of your PC.
There is a lot of info at Singer's website dedicated to the Futuras.
Mar 25, 2010 | Singer CE-200 Quantum Futura Computerized...
I have a futura CE-200 and the bottom LED light blinks and the machine beeps. It does this every 3 to 5 seconds. sews great other than this problem.
Mine was doing the same thing. I took it to an authorized Singer repair shop, and they said the timing needed adjusted. It was only $45 to repair.
Jan 15, 2010 | Singer CE-200 Quantum Futura Computerized...
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
My Futura CE-150 beeps and stops sewing after only a few stitches
Look for the buttonhole lever, just in front of the presserlever, on the lefthand side of the machine. Pull it down and push it back to the top. Good Luck
Jan 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Unable to sew straight stictch with singer futura ce 100
When I had this experience I cleaned the thread path under the plastic cover. There was a piece of thread caught between the disks.
Aug 09, 2008 | Singer CE-200 Quantum Futura Computerized...
Futura software
You have to have all cables connected and machine on to open software
Oct 08, 2007 | Singer CE-200 Quantum Futura Computerized...
Computers & Internet Logo
David Payne
David Payne
