Question about Superstar Radio Communications
Why my monster superstar hotshot not showing me its charging ?
Help with charge
I would suggest charging about 2 oz below label then charge by pressures if it is a TXV. Cap tube is critical charge so i would as the manufacturer of Hot Shot. Not recommended to use hot shot on cap tube systems. My opinion only.
Mar 17, 2014 | Delfield Freezer 6125XL-S
Pantech Hotshot My Verizon
IS the hotshot considered a smartphone? you may need to upgrade the data plan. Another trick by the mobile carriers $$$$$$$$$$
Mar 12, 2014 | Pantech Cell Phones
I need a number password for my pantech hotshot
Unfortunately, there is in such option. Having the phone myself for two years I can assure you I have looked everywhere throughout the phone but there is no option. I too wish there was.
Oct 05, 2013 | Pantech Hotshot Slim Verizon Cell Phone
My pantech hotshot will not change orientation from vertical(small screen) to the horizontal screen with full keyboard that I prefer, what should I do.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 02, 2012 | Pantech Hotshot - Red verizon Smartphone
The Movies Superstar Edition Mac cheats
The Movies: Superstar Edition Cheats, Codes, Unlockables ...
IGNThe Movies: Superstar Edition for Macintosh Cheats - IGN has all the codes, cheatcodes, unlockables, easter eggs, achievements, hints, tips and secrets.
The Movies Superstar Edition Cheats (Mac) - GamesTracker
The Movies Superstar Edition Cheats from GamesTracker. Your source for Mac
Apr 23, 2012 | feral Movies: Superstar Edition for Mac
My verizonwireless pantech hotshots screen won't
Please go to store to fix this problem.
Apr 17, 2012 | Samsung Cell Phones
Can I replace the screen for the pantech hotshot
yes you can buy the kit here, it has
Battery Door and Front, Mid & Back Plates
Feb 06, 2012 | Cell Phones
Trouble charging Monster MCC AVL300 battery
Had same problem, and others have as well. It's not the contacts, but the design of the cradle - the contacts on the unit don't even touch the contacts on the cradle. The only way we get ours to charge is to balance something heavy on top of the remote while it's on the cradle to force the contacts to touch. We use a vase that's on the coffee table, believe it or not.
Apr 23, 2010 | Monster Cable MCC AVL300-S Remote Control
Symbol HotShot LS2106 sounds like it's scanning, but no display
If you are using a USB to PS/2 converter on the end of the USB cable then it won't work. You will need to get a PS/2 cable made for this scanner. I can supply you with one if you need it.
Jul 03, 2009 | Symbol Hotshot LS2106 Handheld
Radio Communications Logo
41 people viewed this question
Top Superstar Radio Communications Experts
Are you a Superstar Radio Communication Expert? Answer questions, earn points and help others
