Question about Kitchen Ranges
My joseph joseph pie kitchen times stopped ringing
How do I usee the wolfgang four piece pie maker?
Hello, Eva -
I hope I am correct in thinking you are asking about a Wolfgang Puck four piece pie maker.
This link is to the PDF document (Adobe Acrobat Reader software required) for model # BPM00020:
http://www.wpcookware.com/instructions/bpm00020.pdf
If your pie maker is a different model, I see the first page of the manual with the link above provides a toll free phone number to call and a web address so that you can contact the company directly and ask how to obtain instructions and recipes for your model.
Best wishes.
Mar 21, 2018 | The Kitchen Appliances - Others
How can I set time? Lost my instructions
Hold the Reset button, then use Start/Stop to confirm and Min and Sec button to change time
Sep 24, 2015 | Joseph Joseph Clip-On Portable Digital...
I have a belling 335 and both the oven and rear left hob ring have stopped working. what is likely to be the problem?
The thermal fuse inside rear is faulty. The grill also has it's own thermal fuse so make sure you change the correct one.
Sep 06, 2012 | Belling 335 Electric Kitchen Range
Clean under agitator on a Kitchen Aid top loading washing machine.
To remove the agitator to gently remove the cap from the top - it will have a rubber o-ring seal. Beneath it there should be a nut and washer assembly remove that. Then there should be a stack of agitator parts - clutch, upper agitator, lower agitator. Set them aside in the order you remove them. then back in the opposite manner.
Hope this helps.
Joseph
Apr 16, 2011 | Washing Machines
Lux timer will not ring
Your very old Lux timer has timed out and needs to be retired.
Aug 08, 2017 | Lux Hardware & Accessories
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
GE electric oven
If this is a fan oven, make sure the fan has not become clogged or has stopped rotating.
Oct 07, 2007 | GE JSP26 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
