Question about Intertherm Heating & Cooling
I need a wiring diagram for a intertherm air conditioner 24 volt circuit
  • 163 Answers
This is a gateway to open WDiagrahm
Posted on May 20, 2017
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
Time delay relay?
it does have time delay but only for loss of power or if someone plays with thermostat making it go off and on. some time delays have a dial to change length of delay. it would be placed in 24 volt circuit to make or break circuit to contactor.
Sep 15, 2013 | Intertherm P3RA-042K Air Conditioner
I have an intertherm furnace. It was working fine on saturday night. tried to turn it on sunday night it won't do anything. The led status light is off. Checked breakers, all good. tested the power...
Hello, test for 24 volts between r and c terminals and for 120 volts at L1 and neutal on the control board, if ther is voltage to the board then the control board is faulty and must be replaced.
Sep 06, 2011 | Intertherm P3RA-048K Air Conditioner
No voltage to gas valve
Check for voltage to transformer, should be 110 volts between black and white wire. Check for 24 volts out of transformer.
Jan 18, 2011 | Intertherm P3RA-048K Air Conditioner
We have the intertherm E2EH-015HA. The AC Coil drain was plugged and the water over flowed and burned out all the wiring. The only wiring diagrams we can find do not show how to complete the circuit for...
The G terminal on the thermostat most go to the G terminal on the control board, so the green wire that is attached to the G terminal on the subbase of the thermostat must go to the G terminal on the intergrated control board on the furnace. I will post a pic of how the wiring goesrobhvac47_8.jpg
Jan 18, 2011 | Heating & Cooling
I have a T3BA-036KA the outside unit will not
You need 24 volts going to the coil of the contactor. If you do not have 24 volts, you will need to trace the wiring back to see where you are losing it from. Try placing your voltmeter at C & Y coming from your air handler. If not, go to your air handler and test for 24 volts ac at C & Y coming from your thermostat. If you do not have 24 volts coming from your thermostat, there is either a problem with the thermostat or there is a problem with the wiring between the thermostat and the air handler. If you have 24 volts at the air handler coming from the thermostat but you do not have 24 volts at the outdoor unit coming from the air handler, then you have a problem with the wires between the air handler and the outdoor unit.
I hope you find this information to be very helpful to you moving forward. Please leave a rating. :-)
May 10, 2010 | Intertherm P3RA-036K Air Conditioner
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Intertherm MGH-056ABFC-91 won't kick on. Just changed thermocouple, gas valve, and thermostat this week. Changed fan motor, blower wheel, and limit switch last winter. Pilot is lit, thermostat is set. The...
At the furnace, jump the R and W (or T and T) terminals on the circuit board or gas valve. Make sure the door switch is closed with some electrical tape. By doing this we are forcing the unit to start. If it does fire, you have either a bad thermostat or a broken wire to the thermostat. If it does nothing, look for a bad fuse, check for 24 volts going to the gas valve, an open limit switch or 120 volts at the transformer.
Nov 02, 2009 | Intertherm P3RA-048K Air Conditioner
I am changing out my intertherm thermostat control. the blue wire is hooked up on B, not on RC, can you tell me why
Because it doesn't belong on RC.
B means "blower" in the antique language of the tradesmen, but nowadays it means "reversing valve". RC means "red cool" or "put 24 volts here to power the cooling system".
The blue wire was not connected to RC because it would not bring 24 volts to the RC terminal.
Jul 22, 2008 | Intertherm Heating & Cooling
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
