Question about Mossberg Optics
How do I disassemble a mossberg 679 30-30 lever action, I bought it new but I have not disassembled it in 30 years
SOURCE: Z2300 satellite disassemble
1. Remove the black face screen. 2. The 4 holes on the satellite that hold the face screen on have a rubber stopper in each.  Pop those out with a screw driver.  There are now 4 screws to take out. 3. The front silver face plate is now only held on by glue.  Take a hair drier around the edges to soften the glue, then carefully pry the front face plate off, being careful not to damage it (I pried it from the bottom so any damage wouldn't be noticed).
Note: the 3 screws on the bottom have nothing to do with removing the face plate.
Posted on Nov 15, 2008
miket756
  • 2702 Answers
SOURCE: I have a 12 gage mossberg shotgun and I need to
yes you can get a brake down picture of the mossberg shot gun its on the internet,,,however its realy easy to strip it down,,,,undo the screw on the end of the for stock and pull the barrel off,,, the triger should never be oiled!!!!! but i give mine a slash of wd40 every 10 years or so????
come on now!!!! the mossberg is a dam good work horse,,,it never needs to be cleaned it just go's on and on! just use it and abuse it thats what its been built for its as strong as a brick built out house
Posted on Nov 17, 2009
daryl441918
  • 1280 Answers
SOURCE: I have a pre 1964
TRY REMOVING THE MAGAZINE PLUG SCREW (WATCH OUT FOR THE SPRING!) TRY HOLDING THE MAGAZINE PLUG SCREW WITH YOUR HAND AS YOU REMOVE IT SO THE SPRING DOESN'T COME FLYING OUT. REMOVE THE SPRING AND TRY CLOSING THE LEVER. IF IT NOW CLOSES THAT WAS YOUR PROBLEM. REASSEMBLE THE SPRING AND SCREW AND YOUR PROBLEM IS SOLVED. IT THIS DOESN'T WORK LET ME KNOW AND MAYBE I CAN COME UP WITH SOMETHING ELSE.
Posted on Dec 02, 2010
SOURCE: We disassembled an Airsoft Mossberg
http://www.youtube.com/watch?v=BTZuUazVZMg
Posted on Oct 06, 2011
SOURCE: Mossberg 800 bolt disassembly instructions
TO DISASSEMBLE BOLT - Depress Safety
Cap' Lock Plunger #8 and turn Safety Cap
# 1 counterclockwise. Striker Spring #9
and Firing Pin Assembly #10 can then be
removed.
TO REASSEMBLE BOLT - Replace firing pin
assembly and striker spring. Insert safety
cap and turn clockwise making sure that it is screwed forward as far as it will go. Then unscrew
until the hole for the safety cap lock plunger is in line
with the cam slot in the bolt. Drop lock spring and
plunger into hole and face cut out portion toward bolt.
Depress plunger and screw cap clockwise until the
plunger is engaged in the recess in the rear of the bolt.
Posted on Nov 01, 2011
Dismal mossberg 85 bolt
Like most bolt action bolts, you have to relieve the spring pressure. That means you need to pull back on the cocking knob on the back of the bolt. The bolt head will come off easily then. The bolt has to be in the exact same condition it's in when you **** the gun. Reverse to reassemble.
May 12, 2016 | Mossberg Optics
How doI disassemble a Mossberg 9200 semi-auto to clean it?
I wouldn't take it apart per-say. use some gun scrubber or brake cleaner. Be careful with the stock and take it off if the solvent would damage the finish.
Mar 24, 2015 | Mossberg Optics
Disassemble bolt on bolt action shotgun
Pretty much all bolt action bolts work the same. You need to relieve the spring force. That means pulling back on the cocking knob. The head will come off easily then. You need to have the bolt in the exact condition it's in when cocked, cocking knob back, to disassemble it. Reverse that to reassemble.
Apr 21, 2014 | Mossberg Optics
HOW DO YOU DISASSEMBLE A MOSSBERG 20 GAUGE BANTUM
Same as all Model 500's. Bolt halfway open, remove barrel, remove trigger group pin, trigger group, both shell stops, bolt carrier, bolt, lifter. Reverse to reassemble. Seriously, head to youtube and watch a video. You can go step by step with the video. The only key spot you need to watch out for is the bolt/bolt carrier when you take it apart and put it back together. The carrier will just ever so slightly clear the front of the inner rail on the receiver....and when you out it back together, put the bolt into that spot, put the forearm back on so the action bars are down next to the bolt, and then drop the bolt carrier back in to link the bolt and action bars back together. Once the cvarrier is in that perfect spot, it'll drop right into the slots. Just slide it a hair forward so the rails slightly block it in and then do the stops. Next key spot....and this is one a lot of folks mess up so don't feel bad. You aren't alone. The pins in the trigger group have to be centered all the way to get the trigger group in right. Use your fingers to center them on both sides, slip the front edges into the trigger group hole to catch the two front tabs, and then GENTLY lower the group in and pin it. DO NOT FORCE IT IN!!! Those tabs break.
Apr 19, 2013 | Mossberg Optics
How do I disassemble the bolt on a mossberg 100 ATR
Apparently the three previous folks have no idea that a Mossbergt 100 ATR is a RIFLE not a shotgun. Regretfully it is a press fit at the rear (multiple splines, pressure fitted into multiple recesses). What that means in English is that it's a factory fix. Sorry!
Apr 11, 2012 | Mossberg Optics
removed.
Oct 26, 2010 | Mossberg Sport & Outdoor - Others
I have a 12 gage mossberg shotgun and I need to clean it. I do all of my cleaning myself. I own several guns. I have forgotton how to disassemble this one though. Can I get some help? Pictures would help...
Nov 16, 2009 | Optics
Optics Logo
43 people viewed this question
Top Mossberg Optics Experts
obsteiner
Ted Maxwell
ray gallant
Are you a Mossberg Optic Expert? Answer questions, earn points and help others
