Question about Philips Televison & Video
I have a Philips DVD/VCR player model 3050V and I have power to the unit but it will not turn on.Is there a fuse inside? keith
  • Philips Master
  • 1,527 Answers
Hi won't be the fuse could be a capacitor fault, or dry solder joint, thanks
shaun
Posted on May 20, 2017
Why after power outtage dvd player don't work?
A power surge sometimes fries the unit it may have a fuse you can replace on the inside
May 14, 2015 | Magnavox Dv220mw9 Dvd Vhs Vcr Combo Player
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Remote for philips model dvp 3050v/37 won't work
Remove old batteries and clean battery terminals with rubbing alcohol, allow seveal minutes to dry and replace the batteries with new ones.
Mar 07, 2012 | Televison & Video
GO Video VR 3845 DVD/VCR combo will not turn on.
Yes,if u want to.Unplug,replug the unit back after about an hour or so.The unit should reset it self out of protection mode and work again,if nothing in the circuit boards are burn.
Jun 15, 2010 | GoVideo Go Video DVD/VCR Combo
Magnavox dvd vcr recorder will not turn on
check fuse inside on board for power u have to take a part
Oct 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR will not turn on.
Remove top cover of the VCR. Then look near the back where the plug-in and power supply is. There should be a little glass fuse. You should keep that fuse and take it to the store and replace it with same exact one. If your VCR can be self-repaired, than this is the only thing you can try.
Mar 11, 2009 | Philips Televison & Video
No power to dvd-vcr player
check the circuit breaker. plug something into the outlet that you know works and see if it turns on.
dont think that there is a fuse inside. If the cables seems good ( ohm it out) then the unit might be shot. sorry...
Feb 14, 2009 | Sanyo DVW-7000 DVD Player/VCR
Philips DVP3345V powers off after 10 seconds.....
If unit has auto rewind \eject feature? Try getting it into F Forward mode befoe it powers down....
Aug 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Problem with my dvd/vcr
detro and guest - that model has a feature that won't allow it to be turned on if there is no video signal present - peruse the www.philips.com/support website for more info
Aug 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox MWR20V6
The unit has to be turned off for the timer to activate. Let me know if it works.
Jul 23, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
