Question about Dryers
Wirlpool dryer duet not heating - Dryers
  • 19 Answers
SOURCE: whirlpool dryer
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Posted on Nov 16, 2008
smkittenfarm
  • 14 Answers
SOURCE: dryer not heating
have you checke the heating element for contanuity, also the high and low limit
Posted on Apr 07, 2009
  • 63 Answers
SOURCE: my wirlpool dryer drum spin but not heating at
If it heats up for a few minutes at the begging and after that goes cold – make sure it is leveled and get good air flow, replace the coils.
If it doesn’t heat up at all, replace the thermo fuse.
Posted on Sep 14, 2009
  • 215 Answers
SOURCE: Is there a way to reverse the direction the door
No not that I know of
Posted on Feb 12, 2010
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
WHY DOES MY WIRLPOOL DRYER MAKE A HUMMING SOUND WHEN TURNED ON
Sounds like there's something in the lower wheel jamming the motor . GOOD LUCK APPLIANCES R EN
May 21, 2014 | Whirlpool GEW9250 Electric Dryer
I have a wirlpool dryer it will not light the igniter will lit but it will not catch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | Whirlpool Dryers
My wirlpool dryer drum spin but not heating at all.the timer count but not heating.
Sep 14, 2009 | Whirlpool Dryers
Heat not working
my wirlpool dryer not heating
Aug 31, 2009 | Whirlpool GEW9250 Electric Dryer
Won't heat
If it spins - you have a problem with the heating elements (usually they are 2 heating elements).I suggest you call a tech and have the deffective elements replaced
Apr 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer not heating
Apr 07, 2009 | Whirlpool LER5636P Electric Dryer
Wirlpool Duet Dryer front Load
I have never seen one up close nor worked on one, but if it was me I would look for a cause to the broblem. I would eliminate the simple stuff like power to the equipment and loose connections. I would then look for the fuse on the dryer and find the blockage or cause of the problem.
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
Wirlpool dryer heating poorly
Make sure you have got it set to full heat and not half heat, you may have a faulty heat selector switch.
Dec 09, 2008 | Dryers
Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
Jan 23, 2008 | Dryers
Dryers Logo
19 people viewed this question
Top Dryers Experts
