Question about Dryers
It will not start. We checked the plug and the circuit breakers and it will not start in any cycle
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Jul 25, 2009
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
What might cause a flashing PF code midway through a cycle? Circuit breaker is fine. Any advice greatly appreciated.
Stop trying to restart it! There is obviously a fault so check your manual. If not in there contact Manufacturer or service agent.
Aug 10, 2014 | Frigidaire Dishwashers
Starts a heat food program on its own.
The logic chip is messed up... replace the whole circuit board
Dec 05, 2013 | Magic Chef Microwave Ovens
Washer fills but trips breaker when trying to start wash cycle. Does the same with rinse and spin cycles and when plugged into another circuit
Hi there
OK thank for writing to fix ya. Sounds like your breaker can't support your washer so you need to replace you breaker where it can handle you washer. just go up another 30amps on your breaker and try that. let me know how that goes.
Best regards Richard
Dec 08, 2009 | Washing Machines
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Maytag MAH5500B FL Washer
Washer Stops
• Plug cord into live electrical outlet.
• Check fuse or reset circuit breaker.
• Close door and push the start/pause pad to start the clothes washer. For your safety,
washer will not tumble or spin unless door is closed.
• This may be a pause or soak period in the cycle. Wait briefly and it may start.
Check screens on inlet hoses at the faucets for obstructions. Clean screens periodically.
If the sreens are colged or even a little sirty it will stop the washer!
Won't fill
• Be sure the door is tightly closed.
• Plug cord into a live electrical outlet. (Tub light should illuminate).
• Press the start/pause pad.!!!!!!!!!!!!!!!!!
• Turn both faucets on fully.
• Straighten inlet hoses.
• Disconnect hoses and clean screens. Hose filter screens may be plugged.
• Open and close the door, then push the start/pause pad.
May be a bad door sensor!!!!!!!
Huuum
Pleae remember to leave a rating
Oct 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
76 people viewed this question
Top Dryers Experts
