Question about Craftsman Garden
Craftsman tractor mower model number 917-287-070 I have to jump the battery off every time I use it its the second new battery
    Habit-Forming:
    New Friend:
  • 26 Answers
Are the connections good between the battery and the cables?
After charging the battery, will it start the mower?
Did you confirm the alternator is charging?
An inoperative alternator is the most likely problem.
Posted on May 21, 2017
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman LT 1000 wouldn't start, it's silent. I changed my battery - still the same.
1. try jumping your mower battery with your car/battery and see if it cranks. If it does, charge your battery. If it doesnt
2. try jumping directly from battery to starter. If that works, its your starter solenoid. If it doesnt,
3. change the starter.
I would need engine model number in order to find your part numbers.
Jun 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won"t turn over, without a jump has new battery
Try adjusting valves. search your engine model number and "valve adjustement".
Jun 09, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Does a bad battery cause my tractor to not turn over?
Yes. Verify it is the battery by jumping mower off with car battery. If turns over, replace battery. If cannot turnover by jumping, try bypassing start solenoid by tapping positive cable to battery post on starter. Starter should turn. If starter doesn't turn, have starter tested.
May 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What would cause a craftsman mower not to have enough power to start #917272672
Low compression most likely. Try changing the spark plug and change the oil. Sometimes the mower won't start if the oil level is too low. If that doesn't correct the problem, then you need to either rebuild the engine or replace it.
May 19, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor will not start
There is an automotive fuse by the fuel tank, this controls the whole electrical system.
Jun 09, 2012 | Craftsman Garden
I have a Craftsman LT 1000 riding mower that just quit running. Won't turn over or anything. Manual suggests checking fuse as one of the options. Only problem is, I can't find the fuse! Manual says it is...
Start with the easiest thing first !
1) jump start the battery from you automobile, or install a charger for an hour. This will tell you wether you battery or connections are good.
If it started with the jump, before you replace a battery:
2) clean the cable ends and make sure cable hardware to battery posts are good and clean.
If it started with the jump, then you know the fuses are good.
If it did not start with the jump or cleaned and charged battery,
3) check the in-line fuse. Located between the key switch and the solenoid, in the wiring harness, normally behind the firewall behind the engine, or in front of the dash close to the fuel tank (if the battery is under the seat)
4) some Sears tractors use a 'relay' also located on the firewall.
Note: for now, let's see how this works. Let me know if you need further assistance. It can get more complicated, but let's keep it simple for now. rwvanlue
Nov 12, 2009 | Craftsman Garden
Kohler engine wont recharge on tractor
Either the stator went out or the voltage regulator is faulty and must be replaced
May 29, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
