My delonghi portable a.c. is stuck in standby mode no error signs it's getting power that's how I know it's in standby mode.
  • Melissa Alford
    Melissa Alford May 20, 2017
    I've read it a hundred times doesn't help on this one
    Sergeant:
  • 163 Answers
  • 56 Answers
SOURCE: DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
Posted on Jan 22, 2008
SOURCE: standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Posted on Oct 14, 2008
projdoc
  • 2237 Answers
SOURCE: sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Posted on Dec 04, 2009
SOURCE: amp err
Same problem here VSX-916 AMP ERR
Posted on Jan 07, 2010
  • 7 Answers
SOURCE: My Pioneer PDP508XDA tv is stuck in standby mode since a power outage
try unplugging and then hold the ower button in untill all lights go out. plug back in and try to power on.
Posted on Apr 14, 2014
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
Tv stuck in standby mode
When a TV is stuck in standby mode often means that there is a problem with its power supply or even in the horizontal output circuitry. May be a component with short-circuit in the RGB output driven by the flyback transformer or a rectifier diode in the power supply output.
I hope having helped you.
Sully
Sep 27, 2013 | Sony Televison & Video
I want to know if the DELONGHI PINGUINO CT110 PORTABLE AIR CONDITIONER 11000 BTU WITH REMOTE have an auto restart after anpower failure
Yes it should, beware that power issues are ******* portable A/C units, most have fuse protection inside the control compartment on the circuit board. Not that easy to get to.
Nov 28, 2011 | DeLonghi PAC T110P 11000 BTU Portable Air...
Just bought DeLonghi portable ac. when i turn it on, there is a empty the tank error reading. Logically, I tried draining the tank and I still get the same reading. This is the second unit to do this. ...
Most likely the float that reads the water level is stuck or broken. Remove the tank and look up into the unit form the opening and se if you can see the float. Move it up and down to free it, if it still gives the error then contact DeLonghi for replacement part(s:
http://www.delonghiusa.com/index.php?texts&pid=15&catid=3
Go there then choose your model and see what they have.
Jun 12, 2011 | Heating & Cooling
Hi I DeLonghi T130ARC model air con and no remote and getting a messgae of PF error does anyone know what this means Andrew
Hello my name is Heath it wil be my pleasure to assist you. The PF usually means there was a power failure and the only thing you can do is turn the power off to the unit unplugg the unit and let it sit for 15-20 minutes and then repower the unit and see if the pf goes away.
Aug 02, 2010 | DeLonghi Pinguino PACL90 Portable Air...
When turn on display reads PF and no AC???
PROBE FAILURE -check their website for the list of error codes here
http://www.delonghi.com/
It says to contact repair department.
Mar 29, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Stuck on Standby, Fujitsu Plasmavision: Model pds4229e-b
I had exactly the same problem with a Fujitsu General PDS4208E. After looking at the forums etc bit the bullet and tracked down an ORIGINAL remote. Paid yesterday, arrived today - batteries in...screen back on!! One proviso here: Before you pay big money for an original remote (and ONLY they will work with these 2nd generation plasma screens not universal remotes) make sure that your screen WAS working before it was in the standby mode. try http://www.portables.co.uk/ on +44 208 968 1444. Ask for Andy. He seemed to know what he was talking about. About £50 +VAT plus next day delivery charge. Alternatively borrow mine at £5 a button press!! ;-))
Mar 06, 2008 | Fujitsu Plasmavision P42VCA30EH 42 in....
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
