I keep getting a a blue box that says program guide is not responding and you can't make it go away
  • 163 Answers
We have lost our tv guide what is on the stations. It did come up but now is saying nothing is available. we have a samsung 42 LCd please can you help
hello there TV guides are normally programmed into a cable or sat box just hit the guide button on your cable or sat box remote and it will show you the TV guide and whats playing on each station however...if your not using one let me know right away
Dec 16, 2017 | Samsung Televison & Video
Been away for three weeks...turn my Hisense back on and all I get is blue screen. I can faintly see all program guides in the background but no channels working, no sound. Can anyone advise?
Please put the set on for few hours and I am sure it will work well. It is possible there is a moisture build up , a weak capacitor in the circuit or a dry solder joint. When the chassis warms up it is possible that the fault should clear or else you will need to open and start by checking from the power to the drives.
Dec 21, 2011 | Televison & Video
Blue smoke when starting frist thing in the morning
This usually indicates worn valve guides. When the engine sits for a period of time, the residual oil sitting in the cylinder head will seep down the valve stems past the seals and guide and into the cylinder. When you fire it up the little bit of oil burns off giving you the blue smoke. Usually clears up right away.
When the guides get worn and theres some play in the valve stem, it stretches the seals a little too so they nolonger seal very well and allow the oil to seep past.
You can replace the seals for a temporary fix, but will not last long as the play will stretch them again. Whats needed is a valve job. Not a quick fix. The valve guides need to be reamed and honed to resize them to fit the valve stems correctly to eliminate sideways play, then the valves ground and reseated and fitted with new stem seals.
Having said all that, if the smoke clears in seconds, you can keep going for a while yet. A little oil burn wont hurt much. As the wear gets worse the smoke will persist longer till it never quite goes away and you leave a trail behind you. Depending on your usage, (and how bad now) this could be 6 - 9 months away.
Hope I have helped.
May 23, 2011 | 2004 Hyundai Santa Fe
I just connected my dct700 motorolaa receiver but i cant seem to see the program guide i can change the channel but i cant see the channels that im in??
its "cold", which means its still downloading. give it 1/2 hour at some point the box will reset and you will see a blue bar with 3 yellow dots. when that goes away toyr box will have a guide and channel bars but they will say no data or to be announced or something of the sort. 10 more min and you will be all set.
hope you didnt mess to much up fussing with it
good luck ;}~
May 10, 2011 | Arris DCT700 DTV Receiver
Windows 7 Blue screen at start up. Shows "Starting Windows" then memory dump/ blue screen. Recovery = No points created by the owner. Roll Back = Tried the 3 points for installs which all still...
Operating System does not respond is the major problem.
This is a very commonly faced error by the users of the Windows 7 which leads to the Blue Screen of death to the system. The error message appears on the computer screen in the following form: "Windows Operating System is not responding" along with two options one "Close the Program" and other "Wait for the program to respond". But whenever the user attempts to close the program he comes up with a serious data loss. To solve this problem apply different troubling shooting methods or take help of the technical experts.
Jan 12, 2011 | Toshiba Computers & Internet
I have an rca remote modle rcu730 and i lost the guide and im trying to program my remote to an symphonic tv and i tried to codes that the computer keep 064 076 and neither of them seem to work do you kno...
Programming using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Feb 01, 2010 | RCA Universal Remote Control
Wii set up problem
that happens all the time, you just have to keep trying it took me 20 minutes once
Sep 27, 2009 | Nintendo Wii Console
I understand that when you try to increase the volume the programs freezes.
To isolate the issue please uninstall HP Quick Touch Software.
Here are the steps to uninstall HP Quick Touch Software.
Click start and select Control Panel
Then select Programs
Then select Programs and Features.
This will show list of programs
There select HP Quick Touch Software and click on uninstall/Remove.
Then restart the Notebook . This should resolve the issue.
Aug 21, 2008 | HP Pavilion dv9000z Notebook
Set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
Sep 16, 2007 | Hitachi 51F710 Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
