Question about Garden
My Honda Generator is running too rich. - Garden
  • 67 Answers
Sounds like a bad airfilter or a problem inside the carb or the choke is sticking closed
Posted on Sep 02, 2009
Why can't i run my a/c with honda 3000is generator
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Jun 03, 2017 | Honda Electrical Supplies
My honda 2000 whisperer generator runs then shuts off after about 3 minutes. What could possibly be wrong?
Always use ONLY fresh fuel... (page 32 of owners manual) it is very easy to forget about because HONDA is such an awesome machine... but EVEN MORE LIKELY...
HONDA has a very sensitive self protection device
Your oil pressure cut off switch could be responding to the WRONG OIL...
DIRTY OIL...
LOW OIL or WORSE... OVERFILLED Oil.
Check it out in your owners manual. ((below) http://cdn.powerequipment.honda.com/pe/pdf/manuals/31Z07610.pdf
Honda Generators Generator Operation
Honda Power Equipment Owners Manuals
http://powerequipment.honda.com/generators/generator-operation#fuel
Feb 10, 2016 | Honda Electrical Supplies
I just cleaned the carb and now it starts and runs fine, but starts burning oil after a couple of minutes. Did I get it wrong on assembly?
There is a series of spacers and gaskets that go on in a specific order. I can't remember offhand. If you get them on wrong it can mess up the alignment of the choke control which causes it to bind up and not move freely. That can make the engine run rich and smoke which makes it look like it is burning oil.
Check online for an exploded view of the gaskets and spacers along with the bracket for the choke control. Make sure they are aligned properly.
Sep 15, 2015 | Honda EU3000iS Inverter Generator
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
Apr 10, 2014 | Honda 84 Atc200 Big Red 200 Engine Stator...
Only runs on choke
it's sound like it need ajustement on carburator because choke only make the mixture air/gas more rich.
Or if it's very cold outside sometimes you have to wait long before out it in normal position. That do to the density of air ... if the adjusment have been made in 25C in summer and now is -15c outside the air is more dense so the motor need a mix more rich.
Jan 10, 2014 | Honda 3000 Watt Portable Generator
Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
Honda 30is generator
dear sir i have one honda 30is it not working when i on the key that showing E-03 what is the problem let me now
Feb 20, 2009 | Honda 3000 Watt Portable Generator
Garden Logo
201 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
