Please help me my give internal error including correpted data
• I receive intermittent error pages with the message "INTERNAL ERROR - Including Corrupted Data error" when I'm trying to print. I've done my own research and tried to fix the problem by re-installin
Data is getting scramble in memory somewhere. Also check for loose connections since one that a not 100% secured in place can cause corruption when the connection is not solid.
Oct 07, 2014 | Office Equipment & Supplies
My camera is showing fomat error what do i do?
Format error message is shown when an unformatted Memory Stick Duo is inserted or when the internal memory is experiencing some problems.The only solution is to format your internal memory or memory card.Please note that formatting the internal memory or memory card irrevocably erases all data, including even protected images.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 30, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My tally data giving error Exiting tally
Please check the path where the Tally has installed.
Dec 16, 2009 | Computers & Internet
Spl-c error - including corrupted data (printer Samsung)
SPL-C -Incomplete Session by time out
Position : 0xddde (56798)
System : src/os_hook
Line :1646
Version : SPL-C 5.35 11-20-2007
Any one can help me how to fix this Error please.
Oct 15, 2009 | Samsung CLX 3160fn All-In-One Printer
I have a Kenmore Elite front loading machine machine HE3 that keeps giving me an error code of F05. What does this mean? Obviously I've lost the manual
"F05" is a heat sensor error code. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Actually, none of the error codes are included with your owner's manual. They are, however, included in the technical data sheet which should be located behind the lower kick panel directly below the door.
If you have any questions, please let me know. I hope this helps you.
Jul 11, 2009 | Kenmore Elite 45986 Front Load Washer
SR-16 gives message "ERROR: 01" when powering up
You likely have lost the internal memory data. This can be due to a power surge or that the internal battery has been depleted. The battery may need to be replaced.
You should reset the unit and reload the data, The manual is available online. Search Google for it.
The manual STRESSES the importance of backing up the data.
If you don'thave the backup, you MAY need to find another SR-16 owner to clone the data from.
Jul 01, 2009 | Alesis Sr 16 Stereo Drum Machine
My samsung ml 2571n print only the first page
motherboard faulty,cannot process data.change
Jun 18, 2009 | Samsung ML-2571N Laser Printer
Once transferred the data to the USB, it shows its correpted.
I recommend that you re-format the drive/device in the system you intend to use it in most.
If you format in the NT mode then your Windows 98 etc will not be able to read the data... this MAY be your problem?
If you are using NT see if it gives you the option to format in 32 bit mode? You MAY be able to use it with both operating systems then.
Hope this helps!
Feb 20, 2009 | Kingston Technologies 512MB DataTraveler I...
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
LOADING DISC
except XP os disk is not oping automatic so please after insert the disk go to my computer and doble clik the f drive it will open still its not open cd is correpted
Jul 03, 2008 | Zenith Data Systems Zenith (OP-260-74501)...
Computers & Internet Logo
David Payne
David Payne
