Door is now unlocked, but I cannot get the machine to start.
Open locked door
To open the door when locked. Start new wash cycle and the door will lock - unlock then lock again. when it unlocks open the door quick.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
Door doesn't unlock, won't start a program
it might just need an update,if not the main board could be going to fail hope not ,not cheep
Nov 03, 2017 | Zanussi WJD1257W Front Load Washer
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
Door won't unlock and cycle won't start
The interlock has failed most likely. Its a small electronic part that the door catch connects into when you close the machine door. Its tricky to release but can be done. Unplug the machine, remove the lid, put your hand down the front of the machine to where the door catch goes in and fiddle until it releases. It takes a bit of luck when you dont know what your looking for.
May 24, 2010 | Bosch Nexxt 500 Plus WFMC5301UC
Help unlocking door
With most machines turn off the AC power and wait until the door clicks then you can open it.
Nov 10, 2009 | Washing Machines
My washer is saying F dL when I try to start a load
can you manage to lock +unlock door buy shutting off machine and starting over .does it run for a while then shut down / if you shut of machine will door unlock .if so ccu board could be problem
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
