Question about Toshiba Office Equipment & Supplies
My Toshiba E-studio 2830C Has error code E010 how do I get rid of it?
  • Toshiba Master
  • 653 Answers
E010 is papar jam error...u need to see where it jam...
Posted on Sep 09, 2017
SOURCE: Canon NP 6030 Error code E010
chiudere sportello superiore destro
Posted on Oct 16, 2009
  • 46 Answers
SOURCE: ''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Posted on Nov 04, 2009
jyackle5
  • 8197 Answers
SOURCE: Toshiba Printer Model #2830C, Error
[CE20] Image quality sensor abnormality (no pattern level)
1. Check if the transfer belt or transfer belt unit are securely installed.
2. Check for any abnormal stain caused by poor cleaning, large flaw or break on the transfer belt
surface.
3. Check if the drum and the transfer belt are rotating. If any abnormality is found, correct any
mechanical problem.
Is the connectors CN345 on the LGC board disconnected?
Is the connector of the image quality sensor disconnected or the surface of the sensor stained?
Is the harness between the LGC board and the image quality sensor open-circuited?
Is the shutter of image quality sensor opening and closing normally? Is the shutter damaged?
Posted on Jan 01, 2011
tonesmaker
  • 60 Answers
SOURCE: What does error code e010 indicate on the Toshiba
open the side door >> you find any paper?? remove it
else you need to change the jamming sensor
Posted on May 13, 2011
SOURCE: Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Posted on Jul 19, 2012
How to do periodic maintenance 0088 in Toshiba Studio 2330c
Toshiba e-STUDIO 2330c
Is given error message "Close Front Cover". The front cover is closed and I can not get error message to go away.
Where can I buy Power Supply (6LG03347000)
Mar 23, 2015 | Toshiba E-studio 2330c 2830c Color...
Toshiba 2330c error cd71
Waste toner transport motor drive locking error.
Jun 10, 2014 | Toshiba E-studio 2330c 2830c Color...
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
To stop auto calibration in toshiba color mfd
Better not to turn off the calibration, otherwise it will cause other errors.
If your colour printing is less than 5% ration, perform following. Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged
number of sheets setting".
08-2693 u can put higher value such as 20 or above to delay the colour calibration.
Mar 25, 2014 | Toshiba E-studio 2330c 2830c Color...
How to solve error code e010 on toshiba 232
Paper not reaching/pass exit sensor, check the exit sensor and actuator (easily break)
Jan 03, 2014 | Toshiba e-Studio 232 Black and White...
Estudio 2830c
Double check your printer driver.
Oct 15, 2013 | Toshiba E-studio 2330c 2830c Color...
Toshiba e studio 282 error code E 010
E010 is a jam up in your fusing unit. Chances are on that model, you have a pickoff finger stuck in an up position. Check for that, if there is just push it back down with a pencil. Otherwise you may have other problems and will need to contact a Toshiba Authorized Retailer for help.
Feb 11, 2013 | Toshiba e-STUDIO 282 Black and White...
Toshiba E-studio 230 Copier shows this message call for service 631012
Well, first of all Francis, that isn't your error code, that's your meter (the odometer of the copier so to speak). Error codes will show C--- or E---
examples are C447 (fuser error) or E010 (fuser related jam)
Jan 10, 2013 | Toshiba E-studio 230 Copier W/net Print,...
What does error code e010 indicate on the Toshiba e-Studio 352 series black and white copier?
May 09, 2011 | Toshiba e-STUDIO 352 Black and White...
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
