Question about Seloc Yamaha Mercury Mariner Outboards 2.5-225HP 1995-2004 Repair Manual 1-4 Cylinder, V4, V6, 4 Stroke, Includes Jet Drives with 1 Year Online Subscription - Seloc
Oops one of my 2005 yamaha 115 4 strokes write to will start but will not stay running, the fuel ball also goes soft. Start will fuel - water separator?
  • Seloc Master
  • 3,498 Answers
Hey Alex, No, I would get a new bulb..check for leaks in the fuel system.
Posted on Jun 20, 2017
WHY DOES MY ISUZU 4HL1 ENGINE HAVE A HARD START ALWAYS?
no car stated, huge NPR truck no less.
no year stated
so no free book information on that engine,.
big diesel. 4HL1, no dash letter?
compression at spec.?
glow plugs work.,
filters clean. water in fuel,
does test fuel (spray'd) help? ???
injection problems
lack of startup air.(filter)
The 4HL1 is a common rail direct injection OHC 16V high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 333 Nm, peak power is 140 PS (103 kW) at 3,000 rpm. Maximum torque is (34.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-N is a common rail direct injection OHC 16V high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 333 Nm, peak power is 131 PS (96 kW) at 3,000 rpm. Maximum Torque is (34.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-TC is a common rail direct injection OHC 16 V turbocharged and intercooled high-pressure fuel injection system engine of 4.777 L capacity with electronic control system. Peak torque is 425 Nm, peak power is 160 PS (118 kW) at 2,700 rpm. Maximum torque is (43.3 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
The 4HL1-TCS is a common rail direct injection OHC 16 V turbocharged and intercooled high-pressure fuel injection system diesel engine of 4.777 L capacity with electronic control system. Peak torque is 500 Nm, peak power is 179 PS (132 kW) at 2,700 rpm. Maximum torque is (51.0 kg m)'/1,500 rpm. Bore is 115 mm, stroke is 115 mm.
May 31, 2016 | Isuzu Cars & Trucks
Hi my yamaha 25 6L2 runs with choke on but when i go to put my choke in the engine will run for about 10 secoundsthen start bogging out it sound to me that the was no fuel getting to the carbs but i...
Runs with the choke on..!??.... the choke cuts off the air supply or in some cases adds extra fuel.. With respect to both, ..they accomplish one thing.. the richen up the fuel mixture..SO with that..,, your engine is starving for fuel ... Its usually the low speed jets are clogged...there are numerous SMALL air and fuel passages that are sometimes hard to clean properly.. Take the carbs to a qualified professional and let him clean and set them.. (if you removed any of the screws that affect the jetting/air/fuel mixture/idle circuit,, they MUST be set back to the factory settings)..
Jun 16, 2017 | Clymer Marine Maintenance and Repair...
Yamaha 115 68v not starting
Do you have spark? What about fuel? Have you tested anything?
Aug 12, 2013 | Yamaha 115 Hp Stator Assy 68v-81410-00-00...
1982 55 yamaha outboard ,water not coming out the water pump hole in strenght
First thing to check: Disconnect the tiny hose between the check outlet and the engine. Disconnect it at the engine side.
With an airgun, blow in the check hole from outside to engine side.
With an airgun, blow out the engine connection.
Start the engine, check waterflow out of the engine connector. If water, reconnect the hose and check the water at the checkpoint.
If still no water at the engine connection: replace the impeller!
Mar 28, 2013 | Clymer Marine Maintenance and Repair...
Yamaha 115 4 stroke engine when it is throttled up it immediately starts to lose power/
Check the vent on the fuel tank. That's most common. Second, check the fuel filter.
Jul 06, 2011 | Yamaha Boating
My Yamaha 4 stroke 50hp engine was running fine. When i went to replace the cover, the water stopped running through the "pee" hole.
i have had this on mine and it was a sort of insect that made a mud nest in the small hole and it blocked the hole up ,try poking it out with a bit of wire
Jun 24, 2011 | Clymer Marine Maintenance and Repair...
Johnson 4 stroke 115 hp will not start. fuel
Sounds like and injector problem to me. If it was a 2 stroke I'd tell you to pull the carbs and clean them ,but EFI is a whole different story. Most certaintly a fuel problem, most likely injector related, you'll most likely need to go see a marine mechanic with the proper equipment to analyze, rather than start replacing parts you may not need.
Jun 20, 2009 | Boating
Seloc Yamaha Mercury Mariner Outboards 2.5-225HP 1995-2004 Repair Manual 1-4 Cylinder, V4, V6, 4 Stroke, Includes Jet Drives with 1 Year Online Subscription - Seloc Logo
185 people viewed this question
Top Seloc Boating Experts
Bill Boyd
Steve P
Steve P
Are you a Seloc Boating Expert? Answer questions, earn points and help others
