Question about Technics Audio Players & Recorders
I have a Technics SL27-BD26. There are no numbers and the arm and skip needs to be adjusted. What can I do?
  • Technics Master
  • 16,984 Answers
Verify the model number first because you have crossed model numbers.
Posted on May 20, 2017
Cannot connect ground wire on SL BD26
Usually, on Technics turntables, the ground wire is attached to a ground lug on the receiver.
Dec 30, 2013 | Technics SL-BD22 Turntable
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
Hi. I'm have a problem with my Technics SL-BD20 turn table I've just purchased. When putting the arm onto the LP it just skips over the surface to the middle. Why does it do that? Cheers.
Try adjusting the tone arm weight so that the arm will be slightly heavier.
If this does not help, see if the tone arm manual lift handle is operational and fully released when the arm sits on the record.
Another possible cause are the tone arm position sensors inside the unit.
Hope you can fix it.
regards
Triarcuate
Oct 01, 2009 | Audio Players & Recorders
Cant find place to order a needle for a technicue turntable.
You can order a stylus 'needle" at the following link.
http://www.lptunes.com/Technics-turntable-stylus-s/321.htm
Jul 20, 2009 | Technics Audio Players & Recorders
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Skipping
That is correct, your tonearm needs to be replaced.
By adjusting that top screw on the tonearm, you only made the problem worse. It's very hard to realign that screw, as those are machine calibrated, and once tampered with, almost impossible to get back to exact factory settings. We recommend replacement of the entire Technics tonearm.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Gear Repairs
Jun 09, 2009 | Technics SL-1210MK5 Turntable
Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 11, 2008 | Technics SL-1210MK5 Turntable
Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Dec 02, 2008 | Audio Players & Recorders
Hi, I have recently purchased a pair of technics 1200 mk2 turntables. One works fine but the other skips, even though I have tried adjusting the height of the arm and adjusting balance etc, no combination...
there may be a weight missing on the arm , look at the other one to see the parts on that arm and make sure they are exactly the same nothing missing , otherwise there may be something wrong with the armitures guide
try tape on a penny then put it on top of the arm and see if it still skips
electech
Oct 31, 2008 | Technics Audio Players & Recorders
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
