Picture sort of flickers on WD=62528 model????
It also turns off when I adjust the brightness too high. Am I looking at a convergence and lamp issue? If so where should I start?
SOURCE: wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Posted on Jan 28, 2009
  • 126 Answers
SOURCE: Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
Posted on May 28, 2009
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
  • 8617 Answers
SOURCE: my mitsubishi wd-62528 has a constant rapid green
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from which contains the capacitors and the CD with instructions for the repair.
Posted on Jul 20, 2010
  • 917 Answers
SOURCE: bright white spots on mitsubishi wd-73833 I just
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Posted on Mar 24, 2011
Screen flickering
A number of possible reasons--from brightness/contrast set too high to a issue with the power supply of the set--a expert would have to examine the set--you might want to call Sony to see if known issue with this model.
Oct 29, 2012 | Sony Grand WEGA KDF55E2000 55" Projection...
Where is the DM Module on a Mitsubishi WD-62528?
A few pieces of advice--the boards are sandwiched in the main signal chassis and not easy to get at.
If you have replaced those 4 in the actual power supply they do for some models sell the entire signal chassis (has almost everything except the optical light engine) for about 250 exchange.
Let me know what issues you have and I may have suggestions--this model has one very odd issue that is simple---picture gets so dark it is hard to see--not the lamp but easy to fix.
May 26, 2012 | Mitsubishi WD-62528 62" LCD HDTV
My girlfriend's Mitsubishi WD-62528 TV has a greenish tint to the picture. Otherwise, the picture seems fine. Any ideas?
First thing I would check is the TV's menu for Color and Hue. You might be able to adjust these to get a more normal picture.
Thanks for using Fixya.
Oct 01, 2011 | Mitsubishi WD-62528 62 in. LCD Television
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Jul 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
It will not turn on
Try to unplug it for a minute, plug it again and see if the green light blinks for about 2 minutes. After that you will probably be able to turn it on. But the blinking light tells you that is time to replace the lamp.
Apr 25, 2009 | Mitsubishi WD-62528 62" LCD HDTV
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
TV does not come on
Similar problem with my Sony. Unplug for 36 hours from the wall and it fixed my problem
Dec 16, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
