Well, never mind. I read online about newer openers need a compatibility bridge for cars to be programmed. Guess I will just use a remote! Bummer
Is there any opportunity to open a docx file with microsoft word 2003?
Hi, there are many way to do so. Following are few online and offline methods/workarounds to read the content of docx format files.1. Open docx with Older version of Office -If you already have older version of Microsoft Office, then you only need to install compatibility pack over existing install. After this install you will able to read docx files in pre-existing Microsoft Office install - download Microsoft Compatibility Pack
2. Compatibility with Open Office -If you have Open Office installed on your computer, then you need to install Open XML Translator to able to read docx files - download Open XML Translator
3. No Software install, convert files to doc format online -I found this method best to able to read docx files without hassles of installing any software. There are number of online tools to convert docx format into doc.
4. Solution for Office installed on Mac - For MS Office install on Macintosh system you need to install Microsoft Office Open XML File Format Converter for Mac - download Open XML File Format Converter
5. Desktop Widget -The Docx-converter Dashboard Widget allows you to convert files right from your Desktop. Simply drag the .docx file you want to convert into the drop area of the widget and the widget will automatically convert the file and save it to the location of the original file - download desktop widget
Aug 11, 2011 | Microsoft Computers & Internet
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
Have a clicker keyless entry with 4 diget code from old opener. klik2 and have new chamblerlin opener model 248735s want to program clicker to open garage door opener need instrustions i can print up
Often times, keypads and remotes are not compatible with newer models, even with the same manufacturer. If you are still interested in finding an instruction manual, try the Chamberlain website. You can also purchase a Universal Keypad, which will work with most models.
Mar 01, 2011 | Chamberlain Klik2u Universal Wireless...
I have a LG 42LD450, I read and saw videos online showing that you can enable video playback through the USB port. I also read that u need a certain universal remote to access the service menu does anyone...
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
Dec 04, 2010 | LG 42LD450 42 in TV
We bought some used tvs for our motel and now we can't program them...with our remote controls that we had previously for our other tvs which were working fine. Model ct2521hb ...do we need to buy another...
Unless old and newer TV's are exactly the same make & model, then full code-compatibility is very unlikely.
Your best bet then would be to get a Universal remote and program it to the newer TV's.
Dec 04, 2017 | Panasonic EUR501371 Remote Control
I bought a cricket broadband device for internet servoces and i tryed to hook it up to my ps3 via usb in the front of my ps3 and it dnt work what am i doing wrong?
Ok-here is your problem, the broadband card (any broadband car for that matter) needs to have drivers and software installed to function- And the ps3 does not allow you to install 3rd party software or drivers - The only way you can use a wireless broadband card ona ps3 is to install linux on your system and use your ps3 as a desktop PC, however the ps3's ability to run linux depends on the model and age of your system, newer slim units (from what I have read) do not support the "Other OS" feature of its predicessors , I own a first gen 80gig with reverse compatability, and run linux (its cool) however I havent had any hands on experiance with the newer systems. if you have a home pc you can buy a router (you have to buy one that supports USB cellular broadband devices-so do some research to make sure you get one compatable with your card) and once you have your card configured to the wifi router you can use the ps3 wifi and get online that way- Bummer I know but I went through the same ordeal using an altel huwawei broadband card
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
Flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
I am trying to move my Bookkeeper program to a new Vista Computer. I am getting a message that I am trying to run an older version of Bookkeeper with newer pogram. My old computer is XP and the new one...
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
• Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
NoteTo find out if your programs (or programs you plan to buy) are compatible with Windows Vista, go online to the Windows Vista Compatibility Center. This website contains a comprehensive list of programs, computers, and devices that have been tested to work with Windows Vista.
Oct 24, 2008 | Computers & Internet
Nero Vision Express 3.1.0.25
same problem, did a lot of research, no fix found, problem with nero dropping frames and not recovering. xvid codec not the issue, many people have the same problem with nero vision. bummer :(
Dec 09, 2007 | Adobe Photoshop 7.0 for PC
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
