Question about Garmin GPS
How do we activited the Garmin nuvi 58lm - Garmin GPS
My Garmin Nuvi 650 has given me a message system software missing. what do i do to get it and what happened for it to go missing???? thanks pb
heres and update click on the link http://www8.garmin.com/support/download_details.jsp?id=1921
or try doing this
the local Garmin support rep and I was given the following sequence to recover from this condition:
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Apparently this sequence will only work with the above error. I hope this assists other if they encounter this problem.
I still don't know why the firmware upgrade process failed BUT after performing the above sequence I found that the firmware upgrade had actually worked (strange).
Mar 28, 2011 | Garmin Nuvi 660 GPS Receiver
No voice to Garmin Nuvi 660
In case it is a software problem try this and see if it will fix it......follow these steps.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to try recover from the problem.
Jan 17, 2009 | Garmin Nuvi 660 GPS Receiver
No voice directions
In case it is a software problem try this and see if it will fix it....Try this and see if it fixes your problem...follow these steps.
Jan 03, 2009 | Garmin Nuvi 660 GPS Receiver
Have Garmin Nuvi 660, after a few min. I lose sats. was working fine for the last year. Just the other day it started. I was in the mountains/ bad weather so I thought that was the problem. I have update...
Dec 24, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin 680 -cannot acquire satellites
If a factory reset does not work, your antenna will need to be replaced.
- Jim
Oct 28, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
Garmin nuvi 660 personal travel asistant
Are you running this unit while it is charging? Does the Nuvi 660 have a sufficient charge?
Try to do a hard reset on the unit.
Dec 13, 2007 | Garmin iQue 3600 GPS Receiver
Won't acquire satellite
There is currently an Update (Vers 5.10) available at Garmin.com Check only the Nuvi 350 click on it and the Nuvi 350 will appear. In the Upper Right Corner you will see a Category of Updates. Click on it and you will be advised that you need to Download UpDater. Do so, uncompress it, then attach your Nuvi to your computer and run Update. It's simple, just follow the instructions on the screen. However, it sometimes take a couple of tries before the Nuvi actually accepts and shows that it has been updated to Vers 5.10 I guess I was lucky. Mine accepted the new update with the 2nd install but it sometimes takes 4 or more. If you are uncomfortable with the foregoing or it doesn't work for you contact Technical support at Garmin. They are really helpful and you can e-mail them at techsupp@garmin.com
Dec 07, 2007 | Garmin nuvi 350 GPS Receiver
Cannot acquire sattelite
I've tried master resets and it does not fix the problem. Only fix is to buy a $30 garmin reciever extension and attach it to the side of your flip up receiver. This is the only fix.
Sep 03, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
